Home | WikiLEC | Repairs | Upgrades | Gallery | Buy & Sell | Mountain Chips | Meets & Events | Contact |
HJ2 wrote:I had a set of greenstuff (the newer compound) on the rears, but i was not happy with them. After a year the pads de-bonded almost completely ! Dangerous, but perhaps exemplary?
Since upgrading to hi-specs on the front I use Mintex M1144 compound all around. A bit dusty, but performance is good from cold an in my limited experience they feel better then the green stuff.
I have been told that greenstuff compound changes regularly so perhaps my info is old now
Rambo wrote:The best front pads I ever had were Pagid RS4-2's, also known as Pagid blues. They were quite expensive but worth it as, when the OEM calipers were properly fettled, they were every bit as good as the HiSpec set up
Wow, indeed the right disc is much more worn than the left one!!!lotusflasherman wrote:look how uneven the disc wear is ...
Giniw wrote:Wow, indeed the right disc is much more worn than the left one!!!
Seriously, that's impressive indeed. Are the sliding shafts working properly or are they a bit seized?
clemo wrote:Are the ones you ( all ) mention above quite dusty on the 16" S2 rim ?
I am now about to be part of the Hi Spec club ... if i can find some conversion brackets.
I have emailed Hi Spec to see if they have any on the shelf .
oh and while I'm at it do the flexi hoses need to be extended ? having just bought some goodrich ones a few weeks back this would be quite annoying .
TA .
clemo wrote:Thanks for the quick reply Phil ...
Phil is the difference between the 15' 16' 17" upgrade just the difference between the size of the conversion kit ?
I have a set of new hi spec's but no brackets . I am assuming that the actual calliper unit is the same . Is this a correct assumption ?
cheers
