Easy Bleed
Easy Bleed
Postby cellaway » Mon 30.10.2017, 14:28
Hi All
I've just bought an Easy Bleed Kit for the obvious reason. The supplied cap doesn't quite fit and the fluid gets forced out over the reservoir by the air pressure. The correct cap for the M100 from S & J ( A100J6077H ) is no longer available. Any suggestions ?
cellaway
Re: Easy Bleed
Postby Giniw » Mon 30.10.2017, 14:52
Hello,
Is it that kind of bleeder? https://cdn.frooition.com/080026/images ... ibleed.jpg
If yes, mine looks identical and works, you should try another cap and/or seal.
It's better to just try with the bleed screw still closed and with air only before you put any DOT 4 in it: if it leaks you won't end up with DOT 4 in the engine bay.
Giniw
Re: Easy Bleed
Postby John_W » Mon 30.10.2017, 17:04
That’s the one I use and it works fine. Are you sure you’re not using too high a pressure?
Re: Easy Bleed
Postby HJ2 » Mon 30.10.2017, 17:36
I have this and had the same problem. The seal was oval somehow but after using one from another cap it worked.
Re: Easy Bleed
Postby cellaway » Mon 30.10.2017, 19:04
The pressure could be a tadge high. I used one of the wheels off the car. Perhaps I should have reduced pressure on the spare, Good tip about no fluid next time. I did try another seal.
According to one of the posts on the forum the cap isn't quite right but if they are no longer available the ideal solution will be difficult. The M100 is a Fed Spec . Does anyone know if the master cylinder is the same spec as the UK ones, apart from the left hand drive bit.
cellaway
Re: Easy Bleed
Postby Giniw » Mon 30.10.2017, 19:53
The spare is supposed to be inflated at >4 bars so yes it's definitely way too much. If I remember correctly the bleeder shoulnd't be pressurized at more than 1.4 bars!
The cap from the bleeder does fit once you select the proper one. I too picked the wrong one first, it did fit but not as well as the second one. And you should keep an eye on the seal indeed.
Giniw
Re: Easy Bleed
Postby cellaway » Mon 30.10.2017, 20:26
I fitted both the caps and one fitted much better so that was the one I used. It appeared to tighten Ok so maybe it is the pressure. I can't remember this problem when I bled the brakes on Cooper S that I had, and should have kept.
cellaway
Re: Easy Bleed
Postby John_W » Mon 30.10.2017, 21:16
Instructions are available at http://www.gunson.co.uk//items/PDF/Prod ... ons_GB.pdf.
It states that “It is recommended that no more than 20 psi is used for bleeding (10psi for older systems)”. I use the spare from a trailer and reduce its pressure to 15psi. If you just connected it to a tyre at 30 psi or the spare at 60 psi the fluid would blow past the seals.
Re: Easy Bleed
Postby Fredjohn » Mon 30.10.2017, 23:21
John_W wrote:Instructions are available at http://www.gunson.co.uk//items/PDF/Prod ... ons_GB.pdf.
Never had a leakage problem with M100, using pressure between 15-20psi.
Did have a seal leak when fitting a new BMC onto the old S4, but used the old seal off the old BMC and it worked :!: :!: :?: :?:
Elan S4 DHC 1969
MB CLK 320CDi 2007
Evora 2010
VW T4 Campervan
Re: Easy Bleed
Postby rip » Tue 31.10.2017, 12:22
How do you get this to fit?
I took 1 look at how well tucked away my reservoir is & decided that I couldn't get near it with this. I even have to use a turkey baster to top it up.
Re: Easy Bleed
Postby Giniw » Tue 31.10.2017, 15:59
Really? Well if you can screw the original cap you should be able to screw the bleeder cap?
As for the bottle I don't really remember where I put it but it was probably near the water reservoir or something like that?
Anyway, even if one should be able to bleed his brakes alone with this, I always prefer to have a helping hand... err head who keeps his eyes peeled on the bottle and engine bay in case anything goes wrong :-)
Giniw
Re: Easy Bleed
Postby simonbuk » Tue 31.10.2017, 16:19
I bought the cheapest one out of Halfords recently, it worked brilliantly !! Just a bottle, plastic tube and a small valve thing - job done !!
simonbuk
Location: Orpington, Kent, sometimes Worthing, West Sussex sometimes The World !!
Re: Easy Bleed
Postby rip » Wed 01.11.2017, 21:36
Giniw wrote:Really? Well if you can screw the original cap you should be able to screw the bleeder cap?
No because the original cap is virtually flat & the bleeder cap has hoses exiting at right angles. The windscreen is too close to give the hoses sufficient room to bend.
Re: Easy Bleed
Postby Giniw » Thu 02.11.2017, 18:05
Strange, I didn't have any problems?! (maybe it's different on a LHD?)
Giniw
Re: Easy Bleed
Postby John_W » Thu 02.11.2017, 20:35
I’ve used it a few times on the Elan and didn’t have any trouble either. I’ll dig it out tomorrow and have a look to see what might be the problem.
Re: Easy Bleed
Postby cellaway » Sat 04.11.2017, 12:07
I did wonder if my fed spec was different to the European cars. Imperial v metric. It's a '91 and if my memory serves me right, car engineering was sometimes caught between the 2 sizes
cellaway
Re: Easy Bleed
Postby John_W » Sat 04.11.2017, 13:58
Rip,
Attached are three photos of my master cylinder and the eezibleed cap and tube. I didn't even bother to take it out the bag, as there's obviously plenty room to screw the eezibleed cap onto the master cylinder reservoir and I couldn't be bothered cleaning the film of brake fluid off everything. There's a clear 2 inches above the fitted cap, and it's only slightly recessed into the scuttle.
My car's a 1991 SE with the original master cylinder and reservoir.
P.S. No turkey baster needed except to remove fluid when fitting new pads. I top up using a small funnel and the bottle of brake fluid.
Re: Easy Bleed
Postby MPx » Sun 05.11.2017, 00:05
I've used my Easibleed on the Elan - but not as easily as others have reported. I found it very awkward to get the master cap off and the easibleed cap on the res as the poor access made it very difficult to get a tight enough grip with just my hand to be able to twist it enough. Maybe I'm unusually feeble! I found that some gentle additional torque with a monkey wrench loosened/tightened it sufficiently and I was able to work around the car very well. I was using the nearest tyre and it would have been pressured to 29lb when I started. However, even with that pressure...and no leaks at the master cylinder end...I still didn't manage to clear all of the air from the system on the first two goes despite the fluid apparently running clear (test drives between). I suspect that there was some air trapped in the proportioning valves that was difficult to shift, but I cant really be certain where it was.
Mike - MPx
95 M100 Elan S2 (423)
86 Turbo Esprit
MPx
