WARNING: Original Front Brake Hose Split
Postby Coupeboy » Wed 13.06.2018, 14:33
During the MoT test today one of the front brake hoses split during the braking test. The hoses are original so in my case 26 years old and 113 000 miles. I had had some braided racing hoses in the garage for a few years which I have never got around to fitting (the fronts with no attachment to wishbone feature) and some replica originals I got from SJ Sportscars late last year but hadn't fiited yet :bonk: . They are going on tomorrow. If you have original hoses I suggest you replace them! I will also do the backs once I get the car back. 8)
1992 Elan Pacific Blue SE
2007 325se Coupe
Coupeboy
Re: WARNING: Original Front Brake Hose Split
Postby ElanBRG » Wed 13.06.2018, 16:18
Coupeboy wrote:During the MoT test today one of the front brake hoses split during the braking test. The hoses are original so in my case 26 years old and 113 000 miles. I had had some braided racing hoses in the garage for a few years which I have never got around to fitting (the fronts with no attachment to wishbone feature) and some replica originals I got from SJ Sportscars late last year but hadn't fiited yet :bonk: . They are going on tomorrow. If you have original hoses I suggest you replace them! I will also do the backs once I get the car back. 8)
That's one of the first jobs I did when I got my car earlier this year. They usually clog up on the inside from deterioration of the lining before you see any damage like splitting on the outside.
Most anything made of rubber on a car needs replacing by the time 20 years rolls around.
91 Elan BRG
ElanBRG
Postby alan e » Wed 13.06.2018, 18:25
How are you getting it home with a split brake hose ?.
Black 1992 M100
Austin 7 1932 box saloon
BMW X5
alan e
Postby Giniw » Wed 13.06.2018, 18:55
With care and/or style? (as long as there is a "branch" of the X system that is working you can brake a little ... OK not very straight, though! :D )
Giniw
Postby alan e » Wed 13.06.2018, 20:02
Under the new MOT rules for a split brake hose ie losing brake fluid this would be classed as dangerous so you cannot drive the car away from the testing garage, but i may be wrong over to you Mr Pink.
Black 1992 M100
BMW X5
alan e
Postby Giniw » Wed 13.06.2018, 20:17
Here in France there is a 24 hours delay so you can bring the car to your favourite mechanic.
Giniw
Postby dapinky » Wed 13.06.2018, 20:53
alan e wrote:..... but i may be wrong over to you Mr Pink.
Since I retired, my recent information comes from the same place as everyone else (Mr Google is your friend!).
However, I would have said that (legalities aside) it is pretty silly to drive a vehicle on a road with known defective braking system.
Okay, so onto the legalities then 8) Clearly, it would be an offence under the Con & Use Regs and Road Traffic Act 1988 to drive a vehicle on a road in a Dangerous Condition - especially as you are aware of the problem.... lots of points and a big fine, with a discretionary disqualification if the Magistrates think it necessary.
Your insurance company would restrict their liability to the legal minimum, so it could be a very expensive drive home.
As for the procedure for an MOT testing station to refuse to release the vehicle, I am in the dark as to how it works (or should work) - I can see no legal precedent for them insisting it stays put (it could even be considered to be contrary to Sec 1 Theft Act, and leads on to allegations under Sec 4 Fraud). I can see no problem with taking it away on a trailer - and would even suggest that an enterprising MOT garage could have a 'local arangement' with a suitable local flatbed driver to everyones benefit.
Postby Saltire » Wed 13.06.2018, 21:29
We haven’t seen a corresponding update to the Sentencing Guidelines yet, but it looks as though the view will be “the onus is on the driver”. In other words, the garage will release the vehicle to you (assuming you don’t ask them to do the work), and it’s then your problem as to how you get it to where the work will be done. But if you attempt to drive it on the road, you’ll be committing an offence as described, aggravated by the “no MoT” aspect, with fines from £400 up to an unlimited amount - and points on your licence.
2010 Fiat Panda 100HP, bossanova white/grey (the rollerskate)
2017 BMW F48 X1 2.0D AWD, Mediterranean blue/magnolia (the workhorse)
Location: Left foot in Wiltshire, right foot in Gloucestershire
Postby John_W » Wed 13.06.2018, 22:26
My reading of the OP is that the garage are going to replace the front hoses and Coupeboy will replace the rest at his earliest opportunity.
Coupeboy - it might be an initial MOT fail, but that's probably the best place for a brake hose to burst! A timely warning to anybody still on the original brake hoses.
Postby Coupeboy » Thu 14.06.2018, 08:49
All correct John. Couldn't have said it better except they are only replacing the burst one as they are busy. Might get it back today/maybe tomorrow - hopefully they can undo the brake pipe union without twisting the pipe. I provided them with my new hose spare. I wait to see what the MoT says. Hours of amusement available here: cardatachecks.co.uk
2007 325se Coupe
Coupeboy
