by Rusty Wishbone » Fri 31.12.2021, 00:32
It looks like my master cylinder requires replacement. Since I have the HiSpec front calipers (& standard rear), I want to stick with the standard MC rather than go for the upgraded one. SJ Sportscars sell one for about £55, but does anyone know of a source of OEM ones please?
Rusty Wishbone
by Saltire » Fri 31.12.2021, 08:14
Rusty, I have the one which came out of my S2 when I went to a smaller bore MC. It’s sitting in a box in my garage and was working fine when removed. Would probably benefit from new seals though.
1995 Elan S2, BRG
2016 BMW 440i MSport
2022 Mini Countryman Cooper S
- Location: Left foot in Wiltshire, right foot in Gloucestershire, heart in Scotland
by Rusty Wishbone » Fri 31.12.2021, 13:48
The trouble is that the seals don’t seem to be available.
Rusty Wishbone
by M100-NC » Fri 31.12.2021, 16:01
Look at this as a replacement master cylinder:
Original Lotus Part # A100J6082S which was replace with A100J6048S
TRW PMF172
https://www.onlinecarparts.co.uk/trw-2208358.htmlUsed on BEDFORD,OPEL ...
Probably the same one SJs is offering since the original has been obsolete since 2003
It will replace the original master cylinder but it is steel instead of aluminum.
It has 4 brake line connections. If you only have 3 lines (Left hand drive cars), you just plug the extra port.
They seem to be around 50 to 60 quid.
I have 2 of them in stock and they look like a good solution.
I am in the US and have a LARGE collection of M100 parts available for sale, both new and used.
M100-NC
by RonR » Fri 31.12.2021, 16:30
After much cross-referencing I think the BMC seal kits are available - Search for OPEL 1605762 on your favourite auction site.
I have an Autofren D1323 from that search here. However I can't confirm that it fits as I haven't rebuilt my BMC yet.
by M100-NC » Fri 31.12.2021, 16:43
I know of one US owner that sent HIS defective Brake Master Cylinder to White Post Restorations over here and they rebuilt it for them.
M100-NC
by Rusty Wishbone » Sun 02.01.2022, 18:52
Thanks everyone. I'm in the process of removing the BMC so that I can inspect it (its a bugger to get at). If I can replace the seals, I will, otherwise I'll call SJ's for a new one.
Rusty Wishbone
by Rusty Wishbone » Wed 05.01.2022, 01:39
Annoyingly, there is what looks like a brake pressure regulator attached to the outlet for the front right brake. It is annoying because it makes both the brake pipe nut for that wheel and one of the mounting nuts for the master cylinder virtually inaccessible. It doesn't appear in any of the workshop manuals - is this a normal arrangement?
Rusty Wishbone
by Fredjohn » Wed 05.01.2022, 10:37
No it isn't! I had to replace that pipe (MC to driver's side caliper RHD) and its just a short pipe with a few bends.
Check you have 2 compensators at the rear!
Also are you sure it isn't just a joint? Check other front side too, if you can.
PS no seal kit available for MC. I bought an SJ replacement MC. The Lotus one was available at the time, but not now.
Elan S4 DHC 1969
Evora 2010
MB E250 CDi coupe 2013
Boardman Endurance SLR 9.4 disc 2018
Rapido 746 2010
by Rusty Wishbone » Wed 05.01.2022, 22:54
Here is a photo of it:
Rusty Wishbone
by Rusty Wishbone » Mon 07.02.2022, 20:22
A few tips for the BMC change:
1. Access to the hydraulic unions & mounting bolts is possible if you remove the power steering reservoir. This means that you can get front access.
2. Buy a couple of flare spanners (10mm & 13mm). They really do make it easier to tackle the hydraulic unions. You can even get ratchet versions, although I didn't try one of them.
3. Check that the pushrod from the servo is in good condition and not scored because this must form a seal as it enters the BMC.
4. There is no seal service kit because the BMC is not serviceable.
If someone wants to add them to the Wiki, please feel free to do so.
Rusty Wishbone
by RonR » Thu 02.06.2022, 19:57
Master Cylinder Rebuild kit:
I can confirm that the Autofren D1323 seal kit is correct for the original 22mm aluminium BMC:
Originals below, replacements above.
It all went back together smoothly, but I haven't bled the brakes yet to check operation, as I need to replace a brake pipe.
