by Hinch » Wed 14.06.2006, 11:03
My Elan has just failed its test on the condition of the rear disks. Braking efficiency was OK but the disks on the drivers side are quite pitted and they failed it on this. Funny that they were pretty much the same last year when the Lotus dealership passed the car. Perhaps I should have taken it back to them again this year.
Well, I am tempted to try and clean the disks up myself and replace the pads to avoid the considerable expense of replacement. Just wondering if anyone has done this, how you did it and if it was successful. Could anyone tell me how easy or difficult it is to replace the rear pads? I have done this on other vehicles and the biggest problem always seems to be getting the piston back into its housing.
They also failed the car on the windscreen wipers which they said did not clear the screen. I tried them myself straight after the test and they seemed to do the job perfectly to me. Are these guys being over zealous these days or what?
Hinch
Hinch
by Enright » Wed 14.06.2006, 12:51
If you give the disks to a good engineering company then they should be able to skim them on a lathe.
I wouldn't have thought it would cost much to take a few thou off them, and the more even/smoother surface may even improve your braking efficiency figures.
Neil
- Modificator
by Exbury » Wed 14.06.2006, 13:33
It might be worth taking it back to Lotus and pointing them out saying that they were like that last year and would they fail them again, and is it an actual MOT failure (not sure) as they did not advise you on their condition. If Lotus say they would pass it and that pitting doesn't fail, maybe you should register a complaint with the MOT agency. You are likely to require a specialist place to do the re-ground, or buy re-ground ones on a px basis.
I believe you need a wind back tool to get the piston back. However I managed to do my mates Honda the other day (with ABS) by using a snug fitting open end of a spanner and a screw driver through the ring and slowly wound it back. Be careful and steady though.
You need to check the end of the blade. If there are cuts or splits in the blade it will fail. It might also be that the wiper has grease on it. Get some vinegar on a rag and clean the blades up with it.
Exbury
