MOT Failure Fron upper Ball joint
Postby Andrew_Ennis » Thu 27.07.2006, 11:25
Car has failed it's mot due to play in the nearside upper ball joint, I spoke to SJS 2 week ago who are apparently getting some made however i cannot get them on the phone or email. Anyway does anyone have a upper ball joint they can sell so i can get the car back on the road. Also looking for a passenger side headlamp lift motor as mine is very unreliable, car keeps winking!!!
Andrew_Ennis
Found ball joint
Postby Andrew_Ennis » Thu 27.07.2006, 11:39
Paul Matty just called, telling me they have just found some in a box. £75/each mind!!!!! :shock:
So just looking for a Passenger side head lamp motor now..
Andrew_Ennis
Postby John_W » Thu 27.07.2006, 11:39
Andrew,
Not in my spares cache I'm afraid. SW Lotus had a (very) few left. Might be worth a call.
Sorry I haven't been in touch - need to talk to you about going to Callander where you have to defend your cup. That gives you 3 weeks to fix your ball joint.
Postby AndyH » Thu 27.07.2006, 11:40
I am having trouble with SJ as well... they have lots of my money and I have none of my parts... can't reach them either... any clues?
Oh, and sorry chap I can't help you. Hope you get it sorted though - weather is too nice to miss a bit of roof down action :D
AndyH
Postby John_W » Thu 27.07.2006, 12:15
SJ's went on their hols at this time last year. I expect their place is shut.
Postby TheBard » Thu 27.07.2006, 14:55
Hey Andrew, if all else fails on the headlamp motor, check out the Corvette parts suppliers, as after a glance at a ZR1 the other weekend, I'm pretty certain that there must be a motor match there...
Not done the full research yet, and am ready to be proved wrong ;)
Good luck,
Ian
P.S. Tried SJs for the window parts I need and got no joy. Called PMs and they had everything in stock, and posted it today :D
TheBard
Postby TStevens » Thu 27.07.2006, 16:16
I have a light motor... but I dont know which side of the car it lives on!....
if i sit it on my lap the spindle is on the left, if the motor is on the side of the housing closest to me.
It's brand new :)
TStevens
Postby ab2cv » Thu 27.07.2006, 17:31
Sure it's the headlamp motor Andrew? Mine was intermittently winking at me but it sorted itself out. I think it was just a dodgy connection coming from the headlamp deployment relay (or whatever its called - black box on the bulkhead)
Alan
ab2cv
Postby Ultimatt » Thu 27.07.2006, 17:50
Don't know if it helps, but I have the same issue with mine. Off-side upper ball joint is buggered.
My mechanic friend believes he may have sourced an original (non-lotus) upper ball joint. He should have received delivery of it today.
Give me an opportunity to chat with him and compare the two and if it's a successful match I'll let you know all the details.
Will be speaking / seeing him this eve.
Matt
M100 Elan SE:
Metallic Gold Fleck Red.
Carbon intake pipes.
Bailey recirculating BOV.
Samco hose kit.
Pro-tech shocks.
S2 wheels.
16" Wilwood Brake upgrade.
S/S Exhaust system.
Everest Chip !
Ultimatt
Postby Paul.P » Thu 27.07.2006, 19:55
Andrew, is it the motor or the bushes gone inside, because if its the bushes, WillB sells new ones for about £9, & its quite an easy job to do.
Postby Specky » Thu 27.07.2006, 20:21
AndyH wrote:I am having trouble with SJ as well... they have lots of my money and I have none of my parts... can't reach them either... any clues?
I can confirm that they are on their Hols... He said my stuff should be with me about the 7th of August, when they return..
Postby AndyH » Thu 27.07.2006, 20:34
Cheers Dave.. They have incurred my displeasure.. 2 weeks leave down the road to fix up my motor, and no parts to fit... I ordered the stuff weeks ago!!... Anyway, moan over :)
AndyH
Postby Specky » Thu 27.07.2006, 20:40
AndyH wrote:Cheers Dave.. They have incurred my displeasure.. 2 weeks leave down the road to fix up my motor, and no parts to fit... I ordered the stuff weeks ago!!... Anyway, moan over :)
I know the feeling :twisted:... you have my sympathy it's going to be a month of waitng for me...
Postby TStevens » Fri 28.07.2006, 00:15
I wish they would publicise the fact they're away, and atleast have an answer.... and the courtesy to process existing orders before they leave and those they cant inform it will be a delay. I got caught out by this last year
TStevens
Postby M100 TWO » Wed 02.08.2006, 14:03
Ultimatt how did you get on with the upper ball joint did you find a replacement ?
M100 TWO
Postby Ultimatt » Wed 02.08.2006, 14:23
I've literally been testing it over the last few days. I need to get the wheel alignments redone but first impressions are a success.
The replacement was not exactly the same as the original, the ball joint housing being approx 2mm narrower, having a slightly different thread size and marginally narrower gap between mounting bolt shafts. However, the shaft is identically sized in width and length, meaning with a new nut it fits perfectly. The only other adjustment required is for the shims. As the width between mounting bolt shafts is slightly narrower the shim holes need to be modified to make allowance and because of the ball join housing being 2mm narrower, you will need to adjust the number of shims either side to ensure correct alignment. This is my next step, just waiting for the new tyres to come through so I can get those fitted at the same time.
If required, I will get the part details and source from my friend.
Matt
M100 Elan SE:
Samco hose kit.
Pro-tech shocks.
S2 wheels.
S/S Exhaust system.
Everest Chip !
Ultimatt
ball joint - top
Postby texas2201 » Wed 02.08.2006, 22:00
I have the same problem PNM have sent thro two and my garage are fiting them this week - well hopefully because we are not sure we have the right one - some kind of Triumph part......
Will post results as soon as i know
car has been off the road for two weeks now :(
Martin
Postby Scott J » Thu 03.08.2006, 11:11
Andrew,
I had to buy an upper ball joint from PM 2 weeks ago. was quoted £38 on-line but they now charge £75 + vat. When I quried it they said its from a different supplier.
I first ctced SJ who didn't have any stock and said original is no longer available, they are in the process of getting patterned ones made.
So PM seem to have a monopoly unless anyone can come up with an alternative part no.
Scott J
The prodigal son
Postby Monty » Thu 03.08.2006, 11:19
SW Lotus was selling them for £50 at Donny a couple years back :?
Postby Ultimatt » Thu 03.08.2006, 12:29
The part I have now fitted is a Triumph part and is a very close match to the original. Don't know what model triumph yet, but I can testify to the fact that with a minor modification (within any DIY mechanics skills) the ball joint will fit perfectly.
Performance is fine, but I will be able to give more of an indication on this when I have my new tyres fitted and alignment re-done.
I believe the price was <£30, but will have to confirm that when I check with my mechanic mate.
Matt
M100 Elan SE:
Samco hose kit.
Pro-tech shocks.
S2 wheels.
S/S Exhaust system.
Everest Chip !
Ultimatt
