by pit_stop » Fri 13.10.2006, 13:17
My Elan SE Turbo has just failed the MOT and the garage guy reckons this is down to it needing discs all round. Leaving the issue of his competence aside i need to find myself a full set of discs asap. I'm not looking for anything fancy, just something to get me through the MOT.
While this site is excellent generally i can't seem to find anything here which gives me some simple and straightforward alternate part numbers. plenty of refenece to the fact that they are both vauxhall from the early 1990's , but nothing that says catagorically what i need to be asking for at my motor factors.
Anyone help me with this plaese. Especially if i've been dumb and missed it on the site somewhere !!
Thanks.
pit_stop
by Dave Eds » Fri 13.10.2006, 13:49
I got Paul Ps old discs in my garage.
He put wilwoods (or similar) on. I'm now going the same route, so his old ones are up for grabs if it helps
Fronts only BTW.
by Sy V » Fri 13.10.2006, 13:58
Description Part number Unit £
Braking | Discs
FRONT BRAKE DISC SJ100J0004 EACH 19.95
Braking | Discs
HIGH PEFORMANCE FRONT BRAKE DISCS Grooved & spot drilled discs, zinc plated for added corrosion protection. SJ100J0012 PAIR 84.90 Add to quote
Braking | Discs
REAR BRAKE DISC B100J0008F EACH 75.00
Braking | Discs
Braking | Discs
RE-GROUND REAR BRAKE DISC SJ100J0018 Exchange 25.75
Braking | Discs
SCREW, FRONT DISC RETAINING St/St SJ100J0005 EACH 0.42
From SJSportscars
INDEPENDENT LOTUS SPECIALISTS
UNIT 1 ASH UNITS, DOWN END
LORDS MEADOW INDUSTRIAL ESTATE
CREDITON, DEVON, ENGLAND EX17 1HN
Tel / Fax
UK: 01363 777790
Just hope this displays OK having cut and pasted it!
- LEC Godfather
