Brake hoses
Brake hoses
Postby hec » Tue 28.11.2006, 19:24
Can anybody suggest an equivalent front brake hose. I have to replace mine for an MOT. I thought they may have been vauxhall but I tried my local dealer and they said no.
Anybody any ideas
Cheers :?
hec
Postby TStevens » Tue 28.11.2006, 19:26
Shifted to brake board.
TStevens
Postby mikeydude » Tue 28.11.2006, 19:56
The best thing to do is upgrade the hoses to braided s\s types. they look better and don't swell like the originals.
I use the googridge type..they do a full kit for the Elan (rear as well) they can be a bit of messing the get right though, I modified the original bracket to suit the new hoses, otherwise they can touch the wheel or suspension etc. and that's an MOT failure.
mikeydude
Postby John_W » Tue 28.11.2006, 20:32
Rambo recommends hoses direct from Goodridge
http://www.goodridge.net/uk/automotive.htm
"Quality stuff and good service - they were received the day after purchase via the internet."
Muley mentioned http://www.brakehoseshop.com/
I got mine from JWracing who sell on ebay, but I can't recommend them.
Postby mikeydude » Tue 28.11.2006, 20:37
If needed I can show you a pic of mine in place.
mikeydude
Pipe failure.
Postby stevieg8571 » Fri 19.01.2007, 16:01
My drivers side front brake sprung a leak during it's MOT this afternoon (embaressing, but glad it didn't happen on the way there) so would appreciate it if anybody knows of an alternative 'off the shelf' replacement that I can source, instead of having to wait for Lotus to supply, and therefore get the car out of the garage asap. (for the garage's benefit aswell as mine!)
Thanks, Steve
stevieg8571
Postby stevieg8571 » Fri 19.01.2007, 17:41
I've ordered a full set of 6 stainless/braided brake lines from SJS (£76 inc VAT & delivery) as nowhere had a single standard on the shelf whilst SJS had 2 of these sets available.
I'm having them sent straight to the garage and the split one will be replaced to get it through the MOT, as all was going well up until that point. I'll have the rest changed at my usual garage asap.
Will these hoses make a noticeable improvement to the feel of the originals?
stevieg8571
Postby Doug » Fri 19.01.2007, 21:48
"noticable improvement" = not unless you are a pro racer
unnoticable improvement = yes
just be sure they are installed and secured properly so that they cannot contact and chafe on the wheel or suspension!
Postby stevieg8571 » Fri 19.01.2007, 23:18
Thanks for the advice Doug, I'll let him know when I call on Monday
stevieg8571
Postby stevieg8571 » Sun 21.01.2007, 14:31
The pipes arrived Saturday morning and the front pair were fitted and MOT finished without further problems by 11am!
SJsports is therefore highly reccomended by me, I wasn't expecting the parcel to arrive til Tuesday at the earliest so getting the call yesterday was a real bonus.
Pipes look good, fitted perfectly and even with just the front pair fitted it does feel better than the originals. I'll get the other 4 fitted asap.
stevieg8571
Postby paza1 » Sun 21.01.2007, 14:37
Hi stevieg8571,
Were they the original hoses? If so, what mileage had they done?
Mark
Silver 1992 SE Turbo.
paza1
Postby stevieg8571 » Sun 21.01.2007, 14:57
Hi Mark,
As far as I'm aware they were the original hoses.
The mileage was 105226 when the front right decided to split, (how lucky was I that it happened on the rollers instead of 20mins earlier when I was 'warming the engine' on the way to the garage!!).
If you're looking into getting the same set, the guy at SJs said he had two sets left, I got one so I'd give then a call soon if you're interested.
stevieg8571
