Failed its mot
Failed its mot
Postby Russc » Fri 27.04.2007, 16:04
Right, just heard it`s failed it`s mot and means i`m going to be doing more that i first thought!!!
Apparently the handbrake is below the standard (even though it sits on a hill most days quite happily) and also doesn`t provide enough water through the washer jets.
Me thinks the MOT station is being a bit picky but there you go.
So i`ve printed of the rear caliper overhall by Mark Alloy and a copy of the service manual. I`m going to check the cable first and if that doesn`t work then i`m going to get stuck into the brakes.
Now, apart from the guides (and the caliper rebuild kit) is there anything anyone can think of i need.
Re the washer jets i`m just going to stick a lenght of wire down it and clean them out.
Looks like most of the car will be in bits, i`ve got new front speakers to fit, a radiator to remove and post and now the rear brakes.
Any ideas or tips to make life easier appreciated :) :) :)
Russc
Re: Failed its mot
Postby ailwyn » Fri 27.04.2007, 16:15
Personally I'd take it to a different tester.
I would think that your issue with the handbrake would be in the cable adjustment as the mechanism itself is pretty simple.
How did they fair on the brakes for the rears (i.e. by pedal)... if they came through free and clear then there can't be much wrong with the calipers.
Ailwyn
Postby Russc » Fri 27.04.2007, 16:17
What a quick response, cheers. I assume that they came through fine as they wern`t mentioned.
There are a couple of places locally that i think would be an "easier" test.
It did also fail on one of the front wheels being egg shaped, that`s ok though as i have 4 spares to change it with :)
Russc
