SAMCO HOSES
SAMCO HOSES
Postby james@amber » Wed 29.10.2008, 12:03
hi,
I thought i would update everybody with the current prices and colours avaliable for the samco hoses, for both the UK and FED spec hose kits.
UK SPEC - TCS330/C
HOSE KIT £275.43
CLIP KIT £40.10
FED SPEC - TCS354/C
HOSE KIT £273.54
CLIP KIT £47.86
COLOUR OPTIONS
BLUE
RED
BLACK
PURPLE
BRITISH RACING GREEN
ORANGE
LIME GREEN
YELLOW
Extra percentage cost will be applied to following hose colours :
PINK +15%
VIPER RED +15%
WHITE +15%
SILVER +15%
CLASSIC BLACK +15%
GUN METAL GREY +15%
BLAZE (FLAME) +35%
CAMOUFLAGE +35%
All prices include UK VAT @ 17.5%.
LEC MEMBERS WILL RECIEVE -20% DISCOUNT OFF ALL THE SAMCO HOSE PRICES
Delivery to UK mainland addresses are £10.00, anywhere else in the world, please email me for a quote.
best regards
james
james@amber
Re: SAMCO HOSES
Postby Sy V » Wed 29.10.2008, 12:17
James
Thanks for this update and the other info ref blank hoses in the main thread.
Your continued support and discounts are much appreciated by all.
Re: SAMCO HOSES
Postby nitroman » Thu 30.10.2008, 05:45
James, I need to swap my unused red kit for a black one (we spoke on this months ago. I'm so faaassst!). By looking at your prices above I should only return the hoses & not the clips, correct? That will also lighten the packages shipped in each direction across the briny blue.
nitroman
Re: SAMCO HOSES
Postby james@amber » Thu 30.10.2008, 10:14
hi,
yeah just send them back, and i will swap them over for you. its ok, the jubilee clips will fit the new black colour hoses :D :D :D
cheers
james
james@amber
Re: SAMCO HOSES
Postby BFG in the BRG » Thu 07.01.2010, 17:50
Just to let you know - I've just ordered a set of Samco's incl SS Clips for a 1992 SE Turbo current price is £262.42 incl VAT and delivery.
The LEC Discount still rocks :banana:
Alas soon to be Elan-less
BFG in the BRG
Three cheers for James!
Postby tigerdog » Fri 15.01.2010, 20:46
...and for Amber Performance for their continued support of the LEC community!
Re: SAMCO HOSES
Postby tomac1975 » Mon 08.03.2010, 14:34
Are these hoses the same for the N/A?
Cheers,
Tom
tomac1975
Re: SAMCO HOSES
Postby Specky » Mon 08.03.2010, 19:21
Good question,
I asked the same question, never gotta an answer thou....
Re: SAMCO HOSES
Postby tigerdog » Mon 08.03.2010, 20:41
Specky, I'd think a quick look would be all that's required if have both a norma and turbo in hand. I'd also think the hoses would be the same, or at least close enough. You obviously wouldn't use the two small turbo hoses and might need to double-check the ones to the throttle body since they connect to the thermostat housing and that's a bit different on a norma. But what do I know? I don't have a norma close by. :)
Re: SAMCO HOSES
Postby Specky » Mon 08.03.2010, 21:15
I would surmise they are the same as well...
the N/A pipes are now located all over the place... :roll:
I could look at the IPC that'd let me know
Re: SAMCO HOSES
Postby BFG in the BRG » Thu 22.04.2010, 21:48
Well, that was fun - fitting the hoses - 7 hours, including project creep - good piece of kit though,
the only problem is I have a pipe left over which I can't find a home for.
If straightened out it would be around 9 inches long and about as thick as your finger.
It is pipe number 2038 - piccie below.
Any ideas? :oops:
It's similar to one of the hoses which sits around the thermostat housing - but I've done all them - part of me thinks it might be round the turbo - but I can't any similar hoses?
'91 SE Turbo by the way
BFG in the BRG
Re: SAMCO HOSES
Postby Andy_J » Thu 22.04.2010, 22:35
PCV Pipe :?: :?:
90H BRG SE 48,000 Miles
Andy_J
Re: SAMCO HOSES
Postby muley » Thu 22.04.2010, 22:36
It looks a bit like the one that got overlooked first time round, probably because it's hard to see - IIRC its around the top of the plenum chamber and one end is tucked away at the rear.
I'll have a close look in the morning.
Re: SAMCO HOSES
Postby tigerdog » Fri 23.04.2010, 04:13
Looks like the throttle body coolant feed. Take a look at the diagram in section KD of the Service Manual. It's really hard to see and a royal pain the change, if I recall.
Re: SAMCO HOSES
Postby BFG in the BRG » Fri 23.04.2010, 22:14
Tigerdog I think you might be right, on both counts - throttle body coolant feed and pain to replace - I'll take a look on my next BRG day - (Thurs). Backs still aching from the work so far - trust me to pick yellow - it just looks grubby at the moment :roll: Still, it will clean up.....eventually. :mrgreen:
BFG in the BRG
Re: SAMCO HOSES
Postby BFG in the BRG » Wed 05.05.2010, 19:57
:ladysman:
You are indeed correct it was
1) well hidden
2) plenum chamber to thermostat housing
3) a bit of a swine to replace - but all done
:banana:
BFG in the BRG
Re: SAMCO HOSES
Postby rip » Wed 05.05.2010, 21:15
BFG in the BRG wrote: a bit of a swine to replace - but all done
:banana:
Only just noticed the thread but I recognised the pipe straight away.
Right bugger to get at. Well done!
Re: SAMCO HOSES
Postby Steve A » Sat 29.01.2011, 15:36
:D Got mine ordered 8)
Re: SAMCO HOSES
Postby Steve A » Mon 14.02.2011, 00:05
:D Fitted them all today, some of them were tough to get at , but the most anoying thing was
all the hoses with the metal clasps :twisted: they were not only hard to get at but a bugger to get off :bonk:
I have very sore fingers :cry:
Was it worth all the effort ?
Whilst changinging the hoses I did wonder, but then found quiet a few mainly the smaller hoses that were in need of changing,
so that's a yes :wink:
Re: SAMCO HOSES
Postby PECKHS » Wed 23.03.2011, 13:37
Are the hoses still available, and may I know how much is it to send to Singapore? Tks
PECKHS
Return to Upgrades
