Dave's shortshift
Postby Elanlover » Fri 13.10.2006, 17:26
markv wrote:
There's only 9 names on that list :?:
Shhhhh! :wink:
Postby GeoffSmith » Fri 13.10.2006, 18:16
What happened to Donsladek?
Presumably ME is Elanlover?
Postby foreleft » Fri 13.10.2006, 19:12
I'd be interested in one from the next batch.
foreleft
Postby GeoffSmith » Fri 13.10.2006, 19:28
ELEVEN?
Postby Ekapol » Fri 13.10.2006, 21:37
I plan to install mine tomorrow :-D How long did it take you all to do it? Is BP energrase LC2 hard to find in the US? Really that we need to soak the pin overnight with WD40? Sorry for all newbie's questions, that is ... what I am :oops:
Ekapol
Postby donsladek » Sat 14.10.2006, 15:33
geoffsmith wrote:What happened to Donsladek?
I'm still in!
Cheers!
Don Sladek
Don Sladek
Calypso Red '91 #37594
donsladek
Postby GeoffSmith » Sat 14.10.2006, 18:16
So it is 11 :)
Postby ESM » Sun 15.10.2006, 12:04
I just had a chat with Jimp357 about the fitting of this with AB cables. Jim says he didn't loosen an adjuster nut on the cable and he agrees that doing so would remove much of the difficulty in fitting that cable (he had a bit a 'doh' moment when he read the suggestion).
I'll leave Jim to post his impressions of the change in the shift.
ESM
Postby Elanlover » Sun 15.10.2006, 14:13
The official unofficial (corrected) list:
ratman
Dave M
discovery
DAdragna
Doc Fizzix
geoffsmith
paulwatkins
donsladek
foreleft
11
Postby jimp357 » Sun 15.10.2006, 16:57
Your not kidding about "doh" moments (had a couple of biggies this weekend :oops: ).
The short shift has given the gear change a lovely feel. Precise, crisp. It just drops into gear a treat now. Very positive.
Fitting. As has been said, easy with hindsight (and probably two brain cells working together). I found that there wasn't quite enough free movement to make connecting the crossgate cable easy. Unlock the rear locking nut (1/2 inch or so) on the AB crossgate cable and there should be more than enough play to fit it. Once on, relock and job done.
There appears to be no interference from the AB cable and the for/aft leaver. Close, but no contact.
As for the component quality. Spot on Dave, excellent job 8) . I can honestly say that I will not be going back to the original setup. This is what it should have been like. :-D
VORSICHT! Die Nordschleife ist gefährlich.
jimp357
Postby kmckmc » Sat 21.10.2006, 23:01
Thumbs up from me. This shortshifter is great! I prefer it to the original.
My mechanic said if he were to install it again. He could do it in 30min.
Great mod!
Elan M100 S2
kmckmc
Postby Ekapol » Tue 24.10.2006, 00:21
jimp357 wrote: I can honestly say that I will not be going back to the original setup. This is what it should have been like. :-D
2nd that :-D Installed mine over the weekend. With 2 washers on the crossgate side. 1 washer on the other side. You can feel the difference with/without washers. Very positive feeling.
I have Isuzu cables and they don't seem to have "lock" & "unlock" feature. Don't know how to adjust them, self-adjusted ? :? The rubber boots (not cables) are touching/squeezing to each other sometimes, but they seem fine to me.
Nicely done Dave :burnout:
Ekapol
Postby Doc Fizzix » Tue 31.10.2006, 16:39
Elanlover wrote:The official unofficial (corrected) list:
ratman
Dave M
discovery
DAdragna
Doc Fizzix
geoffsmith
paulwatkins
donsladek
foreleft
11
Are we a go :smt023
I am ready :D
Doc Fizzix
Postby ESM » Tue 31.10.2006, 18:42
Ekapol wrote:I have Isuzu cables and they don't seem to have "lock" & "unlock" feature. Don't know how to adjust them, self-adjusted ? :?
I have a faint memory that the Isuzu cables adjust at the gearstick end of the cable....
ESM
Postby DeeAitch » Tue 31.10.2006, 19:40
Hi :D Thanks for the feedback - good to hear that those who have fitted the kit are happy with the result. With regard to the cable adjustment the fore / aft shoud be roughly OK without adjustment but the cross gate will definitely need some to get the lever back in the correct position. If Alan is correct then it sounds like a bit of a pain if you have the Isuzu cables :shock:
Got back to work yesterday (after a great trip to NY & Cape Cod :lol: ) and checked the material prices - supplier has agreed to keep them at the previous level for this batch :D so I've ordered another lot. Parts should be ready in 3 weeks so start saving :wink:
DeeAitch
Postby Ekapol » Tue 31.10.2006, 20:26
Thanks Alan. I plan to have the shifter section out for installing Dave M's solid shifter mount.
Currently, the way I feel was just confirmed by Dave's above comments about crossgate side adjusting. So excited that it could even be better than what I have now. :-D
Ekapol
Postby dans » Tue 31.10.2006, 23:06
Only just saw this buy
Can I still get in on this one Dave?? Or are all options taken?
Cheers,
Dan
dans
Postby DeeAitch » Wed 01.11.2006, 00:24
No prob Dan, you're in :D
The official list:
ratman
Dave M
discovery
DAdragna
Doc Fizzix
geoffsmith
paulwatkins
donsladek
foreleft
Dans
= 12
DeeAitch
Postby jabrown39 » Wed 01.11.2006, 02:59
Just saw this also. I don't want to be unlucky 13, but is there still room to jump in? Would love to try it out at Laguna Seca in the the corkscrew and hairpin.
Cheers,
jabrown39
Postby Peter_W » Wed 01.11.2006, 05:04
I just saw this also; can I be added to the list for a lucky 14?
Thanks, Peter
Peter_W
Return to Upgrades
