Car is on the road, runs well on neutral throttle, but hesitate a little on full. Still runs to rich, but I don't dare to lean it out, as i have a boost of 1,3 bar and no knock sensor.
And no knocksensor is a problem.
The easy'st way to destroy the engine is to run lean, next in line is knock, epsecially on high boost.
As the Haltech has capasity to run 2 maps and can flip between the 2 by grounding a wire, I will try to get a signal from the stock knocksensor to trick this, and then let the map2 be retarded 10deg. This should do the trick.
Don't you all think I'm very clever.?.
Actually, it's not my idea but a suggestion I have seen on the Haltech forum.
Well, need to see if it can be done at all.
