Installing Haltech E6GMX
selling haltech
Postby mark » Mon 13.08.2007, 04:54
my haltech E6GMX is for sale - don't have the time to work with it.
see http://www.lotuselancentral.com/forum/v ... hp?t=10382
SOLD to Ailwyn
mark
Postby Robie » Sat 23.02.2008, 21:53
Hi all,
I finished installing the Haltech E6GMx today and have started to tune the car....The hard part is getting it to Idle.
Someone please email a map to me if possible. My poor car hasn't run in almost 2 years now. :cry:
Current setup:
1.6L DOHC
680cc Injectors
Garrett T3/T4 hybrid
Big shoehorn to squeeze it all in.
Thanks!
rblair@robietherobot.com
I have a whitelist enabled, so you might get an email back requesting that you click a link. Just click it or post up that you sent it and I'll dig it out :wink:
Robie
Postby Ashaman » Thu 13.03.2008, 00:23
I haven't been around much latey - but if you still need maps send me a PM!
Ashaman
E6GM
Postby Sy V » Thu 13.03.2008, 10:06
Hey!
Long time no hear!
I saw you offering Robie maps for an E6GMX, could I ask for some too please.
I'm assuming they're e-mailable so sjv@eclipse.co.uk
Many thanks
Sy
Postby Ashaman » Sat 29.03.2008, 23:50
Hey Sy, sorry for the lack of a reply! I didn't see your message for some time, then the car is stored for the winter with a flat battery, so it took me a while to get the current map downloaded to the laptop.
Anyway, I Emailed you a copy, so if you didn't get it, let me know!
By the way, I found that my E6GMX has a firmware bug that prevents the wideband O2 sensor from being logged properly - so if you have any issues in that area I thought I would pass it along.
I was beating my head against the wall trying to figure that out! Anyway, the fix is to ship it back to Haltech for a firmware update (or actually a downgrade I think!).
Personally I am looking forward to getting that resolved so I can have another summer of tuning & driving :)
Ashaman
Postby Sy V » Sun 30.03.2008, 06:40
Received - thanks again.
Sy
Postby Robie » Mon 11.08.2008, 22:52
I just thought I would give a heads up on the Haltech tuning:
I have moved from using 91 octane gas and have completely swapped to E85 (105 octane) since it is plentiful around here. It is also only ~$2.60/Gal too! :-D
With that said, if anybody needs a map to run E85, let me know as I have it running great with 680cc injectors and 18psi boost.
I am currently fighting a wiring/electrical issue that causes some random popping/banging at ~5000rpms, but I'll have them sorted out, which is not an issue with the map.
Robie
Postby Doug » Tue 12.08.2008, 00:38
Robbie,
that's a good savings!
too bad there's no E85 out here--only a few places in all of CA you can get it, but none I can drive to on one tank :shock:
Postby tigerdog » Tue 12.08.2008, 09:10
Robie wrote:...18psi boost.
:shock:
Are you driving an Elan or a grenade with the pin missing? :-)
Back on topic, I've hesitated to use any Ethanol blend because I have never found reference to the Elan's fuel system being designed to be "ethanol-proof". Anyone know of references to indicate it's OK? Also, when you changed the map, what were the biggest areas of alteration?
Re:
Postby Robie » Tue 18.11.2008, 03:28
:shock:
It is a Geo Storm with the same engine :wink:
tigerdog wrote:Back on topic, I've hesitated to use any Ethanol blend because I have never found reference to the Elan's fuel system being designed to be "ethanol-proof". Anyone know of references to indicate it's OK? Also, when you changed the map, what were the biggest areas of alteration?
All cars built after the '80s are able to run with Ethanol mixed into the gas. Here in Colorado, the regular gas usually has 10% mixed in as it is.
When I went to E85, the only alteration I had to do was richen up the mix by ~20%. In some places, I brought it up to 30%.
E85 makes some killer power compared to regular pump gas:
http://www.youtube.com/watch?v=URfSbEt6ukI
http://www.youtube.com/watch?v=rKfKSHodrOE
8)
Robie
Re: Re:
Postby lotos » Thu 20.11.2008, 19:29
Robie wrote:E85 makes some killer power compared to regular pump gas:
In a high-compression modified engine, sure. It's like running 105 octane.
lotos
Return to Upgrades
