Everest chip fitted. But no gains?
Postby Dazm100 » Mon 12.08.2019, 11:04
Ok so before I fitted the everest chip.the car was boosting around .75 on the gauge with piper exhaust 2.1/4 and Watergate ported so fitted the everest chip.but there has been no gain in performance.or boost.checked boost solenoid etc no leaks. Any suggestions?
Dazm100
Re: Everest chip fitted. But no gains?
Postby HJ2 » Mon 12.08.2019, 12:11
Did you perform an elanscan to see what the actual boost is?
Postby MPx » Mon 12.08.2019, 12:13
Sounds like you already had an everest chip to me.
I don't see why anyone would have ported the wastegate (which is done to avoid boost creep) with a standard chip? Having said that, .75 boost seems too high for standard to me, I thought it was nearer .5, but one of those in the know will be along soon with the correct info no doubt.
Is this on an S2? If so, your set up (everest, port, 2.25 piper) is the same as mine and the difference between std and this is 40 to 50 bhp and very noticeable. The only other difference is that I have a Pre-Cat Eliminator and sports cat in the exhaust which obviously will improve gas flows - indeed if your pre-cat has started to break down then that alone could stifle any gains.
Good luck with it. A rolling road session may be needed to see where you actually are...
Mike - MPx
95 M100 Elan S2 (423)
86 Turbo Esprit
MPx
Postby theelanman » Mon 12.08.2019, 12:37
there was a kilimanjaro chip that was also available with less boost........
it could have been that chip........
Postby theelanman » Mon 12.08.2019, 12:38
Maximum programmed boost 0.8bar
Fuel cut limit 0.96bar
Boost pickup rate enhanced
Dyno power 180bhp (flywheel estimated)
Postby Dazm100 » Mon 12.08.2019, 13:20
There was no other chip fitted.untill I fitted the everest chip. Not sure how accurate the standard boost gauge is?but when I fitted the everest chip didn't see no performance gains at all. Just same boost reading
Dazm100
Postby Dazm100 » Mon 12.08.2019, 13:21
Forgot to ad s1
Dazm100
Postby theelanman » Mon 12.08.2019, 13:28
something definitely wrong here.......
can you get an elanscan reading?......
where/who did you get your chip from?........
Postby Brit-Car-Nut » Mon 12.08.2019, 14:12
Probably would be good to provide some info: Where did you get the Everest Chip? Did the ECM already have a GREEN adapter board and chip installed? If NOT, did you get a GREEN adapter board with the Everest Chip?
A few pictures might make it easier to answer.
Of course, your Wastegate could be seized and until it is working, the boost range will not change.
Lotus Manuals
Postby Dazm100 » Mon 12.08.2019, 14:38
Bought the everest chip off the shop off this forum.
It came with the green adapter board.
Will post pics of the ecu
Dazm100
Postby John_W » Mon 12.08.2019, 16:19
It would also be useful to see some pictures of the small-bore pipes to your BSV and turbo wastegate control capsule to check that they’re connected correctly.
As Gareth mentioned, Elanscan readings would be useful for diagnosis also.
Have you checked base timing?
Postby HJ2 » Mon 12.08.2019, 17:41
I’m HJ2, not Gareth :lol:
Postby Rambo » Mon 12.08.2019, 19:45
Postby Dazm100 » Mon 12.08.2019, 19:49
Yes there alot of fluttering?
Dazm100
Postby Dazm100 » Mon 12.08.2019, 19:52
That's with open filter just fitted. (Ramair)
Dazm100
Postby Rambo » Mon 12.08.2019, 20:09
Check carefully that the wastegate is actually working correctly so you can eliminate this from the possibilities.
I'm fairly sure you can check if the wastegate capsule is also working correctly with the use of a bicycle pump. Phil ?
Postby quiksilva » Mon 12.08.2019, 20:47
Hi Daz,
might help to add where you are in the world so someone local with an elanscan laptop could get in touch to assist if you havent got access.
On the subject of freeing the wastegate there is a wiki article about complete removal of heat shield and capsule to free it up but being honest after removing 2 of the 3 bolts to the wastegate actuator i thought sod this for a game of soldiers as there was no way they were going back together without a lot of blood / swearing / raging (just me and me big pinkies) and so for all the time ive owned the car ive always used these long nose long handled pliers from snapon - they dont slip on the shaft and due to the length of the pliers i can force the actuator rod fully across its horizontal travel by pivoting from above. once freed up i force the rod over to the left and hold it there whilst with the other hand i give it a squirt of aerosol copper grease onto the bit of shaft that is normally inside the capsule just to keep things lubricated a bit that end
regards
andy
The most successful people are those who are good at plan B.
1992 BRG Elan SE, Wilwoods, Killimanjaro Oh & a bl**dy big grin.
quiksilva
Postby Dazm100 » Mon 12.08.2019, 21:19
Thanks Andy will give it a go tommorow.
Dazm100
Postby HJ2 » Tue 13.08.2019, 08:38
I use the same technique, but different pliers.
Works like charm indeed!
However i don't use any grease as it tends to seize up due to temperature induced decomposition...
Postby Rambo » Tue 13.08.2019, 08:51
From the link I posted....
"There is not a consensus on whether to lubricate the wastegate shaft or not. One strong argument against is that, because of the extreme temperatures involved, most lubricants will degrade rapidly which may cause the wastegate to stick again and may even carbonise which can cause excessive wear. Any expert opinions would be gratefully received. [In the absence of expert opinion you'll have to make do with mine for the time being: CopaSlip type of lubricant is rated to 1100°C which should be adequate - Geoff]"
Return to Upgrades
