CLEMO'S SUPER BOOT RELEASE...
for this you will need .
1 x bike brake cable.
1 x electrical block connector.
2 core wire.
fuse.
spade connectors.
1 x saab boot release mecanism or door central locking mech.
1 x saab boot switch.
tools.
wire cutters
drill.
screwdrivers.
first you must work out where you want your boot opening switch to be.
as shown mine is in the door.. my reason for choosing here is that it is hidden by the seat (when the roof is down) .
[img]C:\Documents%20and%20Settings\dave%20clement\My%20Documents\My%20Pictures\boot%20001.jpg[/img]
I then removed my door card to fit the switch .
i then to a 2 core wire through the door , door hinge cable trunk, along the sill and drilled a small hole in the door slam post , under the carpet where it cannot be seen and hooked the wire up into the battery compartment.
[img]C:\Documents%20and%20Settings\dave%20clement\My%20Documents\My%20Pictures\boot%20006.jpg[/img]
i then took the wire up to the battery (using one side of the wire for the power) as shown and put an inline fuse in. at this point it is attatched to the battery and then snt on its way to the boot , passing under the plastic battery cover surround and up and through the rubber gromit .. now we are in the boot.
from the boot i used some plastic covering to keep in neat and tidy i take the wire up to the rear of the SAAB boot mechanism (which is double sided number plate taped to the inside of the boot lid.
[/img] C:\Documents and Settings\dave clement\My Documents\My Pictures\boot 002.jpg
Cannot upload moore than 3 pics. and using the old style it seems not to post the pictures... 1hr 30 later...
give me an engine rebuild ...yes.. give me a blinking computer .. AAAAAAHHHHHHHHHH.
off to kick the cat....
oh ... haven't got a cat.
