Plastidip your wheels
Postby HJ2 » Sat 09.06.2012, 20:58
Here's what I did for the Ypres Lotus Day with my wheels
Google the stuff, it's brilliant! If you don't like it, you can rip it off again without a problem. ;-)
Here's what I wanted (Porsche rims ;-) )
My winter rims
Wrap the details first.
Full spray, twice
I just want the centers black, so only over spray on the outer edges (saves paint :lol: )
dry...
2 layers and fully dried
Rub the overspray away with just your thumb.
The tricky part: cut the separation line in one fluent movement. Use a fresh and sharp blade (24 Swann-Morton, quality British steel :bananasex: ) and apply mild pressure. If you're not used to this tool and you don't want to damage the paint below: practice one something else, more cheap, before you do your wheels! It is possible to cut the plastidip layer without cutting the original paint. Be brave!
Peal away!
Clean the entire edge
I like it already!
I don't want to loose my wheels, so all mating surfaces need to be cleaned as well
Almost done
refit centers
Presto!
Time per wheel: 1,5 hours. 3 cans of paint in total, 2 layers outside, and 1 layer inside.
Re: Plastidip your wheels
Postby hatters » Sat 09.06.2012, 21:58
Good job. They look ace on the car !
hatters
Postby texas2201 » Sun 10.06.2012, 05:26
hatters wrote:Good job. They look ace on the car !
Ditto - you must have a steady hand :-) to cut a consistent line like that
http://www.extremepetrolhead.blogspot.com/
Postby DeanG » Sun 10.06.2012, 18:09
Thanks for the tip. Let us know how it stands up.
DeanG
Postby rip » Mon 11.06.2012, 11:10
That looks great. Must try it out on my daily.
Postby Doug » Wed 13.06.2012, 00:38
Very Nice. Thanks for sharing :smt023
Postby tweetdriver63 » Tue 26.06.2012, 00:40
Nice job. Can you explain "2 layers outside, 1 layer inside?"
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby HJ2 » Tue 26.06.2012, 08:20
Yes!:
The visual side of the wheel (or front, or outside as i call it) had 2 layers of paint.
Then the inside (or rear) looked still grey or metallic which doesn't look very good, so it should be black as well. I did this with only one layer of paint.
Postby Nas » Thu 20.09.2012, 17:08
I've been hearing about this process on and off over the past year now, and after to admit I sort of just fobbed off the idea. But I really will not any longer, that jobs looks very good / high quality!
I think this will be something I'll have to venture into in the near future, just hope its a durable / lasting product for a reasonable length of time.
Nas
Postby norman lovie » Sat 22.09.2012, 17:05
HJ2 wrote:Image
thats the nicest picture of a M100 i,ve seen - you've just got it right from the angle you've taken the picture, i've not been able to get a photo to show what this car look's like in the flesh, but this one does it - nice one
norman lovie
Postby HJ2 » Sat 22.09.2012, 19:03
Thanks very much man!
I like them as well, and it shows our tiny house in the old city of Delft very nice :-)
Postby norman lovie » Sun 23.09.2012, 11:52
it's now my desk top back ground
norman lovie
Postby HJ2 » Sun 23.09.2012, 11:57
That is just too much honour! :cheers:
Postby HJ2 » Mon 01.10.2012, 10:28
This week the plastidipped wheels are going back on the car so i can keep you folkes posted aboud the long term experience with the stuff...
Postby HJ2 » Wed 10.10.2012, 19:53
I just put them back, ready for winter now!
There were some minor scratches that I ' repaired' with a local respray. No masking involved, very easy to do.
To be continued...
Postby Steve A » Wed 10.10.2012, 23:02
:goodposting: :smt023
Postby *LUCA* » Mon 15.10.2012, 07:29
:agree: :agree: :agree: :agree:
WoW...what a great job, my compliments Henk-Jan!
*LUCA*
Postby mtp » Mon 15.10.2012, 14:37
Looks nice seen that paint used on gun stocks .
1 question the part where you cut and peeled off. have you had to seal that lip
or is it sealed tight (dried) so it wont lift
thanks mtp
mtp
Location: Durham area (website best viewed in i.e 7 plus)
Postby HJ2 » Mon 22.09.2014, 09:48
I dipped my winter-set, but in summer i really missed my plastidipped wheels, so i painted my other set as well.
What do you think?
Postby Don.Hasi » Sat 25.10.2014, 09:43
Looks very cool 8) do you wash your car by hand or do you use also carwash-facilities ? Does the rubber of the car wash peel the dip off?
Don.Hasi
Return to Wheels and Tyres
