Spigot Rings
Spigot Rings
Postby simonbuk » Wed 13.04.2016, 22:11
Having taken all my wheels of recently I noticed they what I think you call a white plastic spigot ring. I also noticed that the last wheel I removed was missing one.
Is there any real point to them ? Surely the wheels should fit no problem ?
I've tried to work out the size if I need some and think its going to be this size -
http://www.ebay.co.uk/itm/SPIGOT-RINGS- ... 0495879289
Am I correct ?!
simonbuk
Location: Orpington, Kent, sometimes Worthing, West Sussex sometimes The World !!
Re: Spigot Rings
Postby Rambo » Wed 13.04.2016, 22:14
Never heard of anyone having these things with either SE or S2 alloys
Goldfish-brain
Re: Spigot Rings
Postby Rambo » Wed 13.04.2016, 22:16
Just blown up your avatar. Not literally of course ! Looks like you have non standard wheels so I presume they're some kind of spacer to centralise the wheel on the hub ?
Goldfish-brain
Re: Spigot Rings
Postby simonbuk » Wed 13.04.2016, 22:18
Yes, sorry should have said. They are Enzo B 16×6.5 - 100/45/60.1 ( found the delivery note)
simonbuk
Re: Spigot Rings
Postby lotusflasherman » Wed 13.04.2016, 23:03
simonbuk wrote:Is there any real point to them ? Surely the wheels should fit no problem ?
If you have non-standard wheels where the bore is larger than the boss on the hub, spigot rings just help centre the wheel to get the wheel bolts into the holes.
Without them you may need to lift the wheel a bit to get a bolt into a hole. They just make life easier but the taper seats on the bolts pull the wheel into 'true centre' so spigot rings are not essential.
Cars: Subaru Forester 2.5XTN, Eclat Riviera & brace of Pacific Blue SE's.... and now an Elan+2S !
Re: Spigot Rings
Postby Grant » Wed 13.04.2016, 23:12
Some wheels/hubs are hub centric others are bolt centric. I believe Elan wheels are hub centric, meaning if you have after market wheels you do need the rings to properly center the wheels. Also the weight of the car should ride on the hub, not the bolts.
Grant
Re: Spigot Rings
Postby lotusflasherman » Wed 13.04.2016, 23:48
Grant wrote:Some wheels/hubs are hub centric others are bolt centric. I believe Elan wheels are hub centric, meaning if you have after market wheels you do need the rings to properly center the wheels. Also the weight of the car should ride on the hub, not the bolts.
Think I have to disagree with you. Hub centric wheels usually have sleeve nuts with flat washers and the hub flange centres the wheel but still the weight of the car is carried by the wheel being bolted to the hub flange, at the correct torque it shouldn't move. Unless the wheel is an interference fit on the hub it cannot relieve the load on the bolts. The OE wheels are an exact fit for the 56mm hub flange but taper seats suggest it's the bolts that centre them.. 'belt and braces' maybe?
Re: Spigot Rings
Postby Grant » Thu 14.04.2016, 22:25
I am certainly no expert. I just had read that it is important for the weight of the car to ride on the hub vs. the bolts. I have always used metal spigot rings.
www.lotuselancentral.com/upgrade/wheels.htm
Grant
Re: Spigot Rings
Postby Simon_P » Fri 15.04.2016, 16:51
The weight of the vehicle is borne by neither the hub (centre) or the bolts. This Is a description of how the wheel is centred, not how the weigh or drive are transmitted.
The bolts clamp the wheel to the hub face, and the face transfers the loads.
Return to Wheels and Tyres
