New tyre selection for 15" wheels
Re: New tyre selection for 15" wheels
Postby surfboardfiller » Fri 17.03.2017, 17:03
Toyo Proxie are cheap and ok ish, (surprisingly good in fresh snow for a summer tyre!) I wouldn't buy them again for an Elan or other sports car. They wander in the wet and rutted/ridged surfaces due to the poor tread pattern and their dry grip is not good either. Its not a sports car tyre - mid range at best.
Uniroyal rainsport are excellent all weather tyre, superb in the dry and amazing in the wet
Yokohama Advan AD08 were amazingly good but that was a while back
Yokohama C Drives were fine in the dry/not brilliant, poor wet grip
Yokohama Parada Spec2 are shocking in the wet - I was properly scared
Yokohama A539 weren't great especially in the wet compared to the AD08 I had before
Michelin Pilot Exalto Sport were brilliant but... are now NA in 15" I still have a pair
Goodyear EfficientGrip Performance - are NA /55 ratio but not 50
Pirelli P Zero nero/corsa - are NA for 15" Elan wheels "There are no products based on your selections"
Dunlop - are NA for 15" Elan wheels
Bridgestone Potenza Adrenalin RE002 - I am buying at the moment so this could be interesting. Edit: there are less than 100 tyres left and there will be no more so this is it. :(
surfboardfiller
Postby clemo » Fri 17.03.2017, 20:10
surfboardfiller wrote:Toyo Proxie are cheap and ok ish, (surprisingly good in fresh snow for a summer tyre!) I wouldn't buy them again for an Elan or other sports car. They wander in the wet and rutted/ridged surfaces due to the poor tread pattern and their dry grip is not good either. Its not a sports car tyre - mid range at best.
What are you running on the track Elan Phil ?
I found the toyo's to stick extremely well round the ring on my old track slag . grip way further than i thought there was grip .
I used to run Goodyear eagle F1's on the S2 wheels . Really liked the feel of them but haven't found anything close to them since they stopped making them .
Jim Clark S2 - 1/13. The one with the Yellow spoke wheels . No 613 on dash (pushed in to factory in wrong order 615 on tub)
clemo
Postby surfboardfiller » Fri 17.03.2017, 23:52
Track car has R888 but they are on my custom Compomotive 16" wheels (to fit the big 4 pot brakes).
They will probably be replaced by Yoko A048 or other road legal track tyre.
surfboardfiller
Postby markv » Thu 15.06.2017, 13:32
I thought I'd post an update one year on. Very pleased with the new Toyo Proxes - they have improved the car's handling significantly (and the mpg). I only wish I'd bought them sooner, rather than squeezing every last mm out of the (very) old tyres I had on the car.
Return to Wheels and Tyres
