Candles wrote:I cannot get to the pipes to undo them, nor can I undo the nearside mounting nut! I've got the arch liner out so the offside nut was a piece of old wee, but I'm stumped with the rest! I'm almost tempted to just cut through the pipes and make new ones for the reinstall!
nitroman wrote:What is the bore of the BMC (ie, 1-1/8" bore?)? Also what is the distance between the two bolt-holes? In other words, is it a GM standard "mounting-pattern" like this one? http://www.ssbrakes.com/products/detail ... (0%20-%200) Seems if we knew some of these figures we could go up in bore size yet still find a bolt-in BMC. Comparing bore & stroke of various units (ie, Bore = 0.7”, stroke = 41 mm movement) makes it easy to compute total fluid movement VS pedal travel.
1998 PONTIAC TRANS SPORT MONTANA 3.4L
GeoffSmith wrote:Don't know if this helps, but I think they may be M15 x 1. Check out the two Raybestos ones listed on Rockauto. The first design lists M12 and M15 outlets but the second design lists M12 and M10.
It looks like ESM's identification of the Pontiac LeMans might have been correct, just that there are two versions fitted.
RAYBESTOS Part # MC39869 {Professional Grade Bore Size=7/8" Number of Ports=4 Primary Outlet Size=M12x1 Secondary Outlet Size=M10x1}
2nd Design $128.79
DORMAN Part # M39869 {First Stop}
w/Power Brakes; Bore = 7/8"; Stamped 2631 on Booster $107.99
