by Simon_P » Sun 12.08.2007, 20:51
Monty,
I see you wrote rubbish to my earlier post. The Lotus filter has a round surface to the seal and the aftermarket ones have tried have a flat surface. I have found that the one with the round bead is easier to get off than a flat bead which sticks - probably because the contact area is greatly reduced and it doesn't need to be done up as tight to seal corectly.
Doug, Ellie,
There is a lot of sience in the design of rubber seals. The lotus oil filter seal looks similar to the K&N one above .... And I quote "Internally lubricated gasket provides positive seal while allowing easy on and off of filter" from the K&N website.
by Monty » Sun 12.08.2007, 22:57
Simon_P wrote:Monty,
Yep, and it`s still rubbish lol
The last 3 years off serving the M100 myself i`ve never had trouble with getting the oil filtter off
But i do fancy going for the K&N next time
- Chunder King!
by Simon_P » Mon 13.08.2007, 14:03
Monty,
Just sharing my experience - The flat seal stuck - the Elan filter is difficult to get to.
In 3 years of Elan servicing you've changed how many filters?
by Ellie » Sun 19.08.2007, 02:02
Elan Factory in Melbourne has some useful info for early Elans, M100s and other Lotus models... see link
http://www.elanfactory.com.au/pdf/produ ... ilters.pdf
They also give the oil filter size as h= 82mm/3.23" ; OD 78mm/3.07" ; thread M20x1.5 metal canister.
See below - attached pdf with a filter reference list to make things easier.
Edit 18/1/08 these web pages with oil filter performance comparisons may interest some
people.msoe.edu/~yoderw/oilfilterstudy/oilfilters.htmlminimopar.knizefamily.net/oilfilterstudy.html
Ellie on Fri 18.01.2008, 14:05, edited 4 times in total.
S2 #161 Calypso Red & fun in the sun. S2 means seats two, and I aint walkin'!
Growing old is mandatory; growing up is optional.
Ellie
by Dico » Sun 19.08.2007, 10:20
I've changed 7 in less than 4 years (all by hand). None stuck
No wimps oop north
- Fool Boy Four - Founder
by jordizr1 » Wed 23.04.2008, 16:10
Nobody has ever tried to put a remote oil filter kit in their Elan?
I guess it would simplify oil changes a lot
yes it's mine and no you can't drive it
jordizr1
by rip » Wed 23.04.2008, 21:20
jordizr1 wrote:Nobody has ever tried to put a remote oil filter kit in their Elan?
Not too sure about the sound of that. Remote=extra plumbing. Not a lot of space to start with. You would also have to pump the oil the extra distance to the filter & back again.
I'll keep my filter where it is thanks. As for burning my arm on the hot plenum:.. that's what my old worn out leather jacket is for
by Dave Eds » Wed 23.04.2008, 22:23
rip wrote:.. that's what my old worn out leather jacket is for
What, the one you wore at Donington?
by GeoffSmith » Wed 23.04.2008, 22:25
rip wrote:As for being poached to death when the head gasket explodes:.. that's what my old worn out leather jacket is for
- Kitty Fiddler
by Dave Eds » Wed 23.04.2008, 22:26
GeoffSmith wrote:rip wrote:As for being poached to death when the head gasket explodes:.. that's what my old worn out leather jacket is for
and a waterproof banana on his head
by GeoffSmith » Wed 23.04.2008, 22:35
Dave Eds wrote:GeoffSmith wrote:rip wrote:As for being poached to death when the head gasket explodes:.. that's what my old worn out leather jacket is for
or
- Kitty Fiddler
