by surfboardfiller » Sat 16.01.2021, 17:30
I just fitted a Bosch/02 Mercedes C Class W203 C220 2.2 CDI Auxiliary Water Pump 2038350064
Perfect fit. £14.70 used
surfboardfiller
by Tuga2112 » Tue 03.08.2021, 10:34
surfboardfiller wrote:I just fitted a Bosch/02 Mercedes C Class W203 C220 2.2 CDI Auxiliary Water Pump 2038350064
thanks Phill.
Ordered a pair of new ones from autodoc for both Elans, Will update when they arrive
by texas2201 » Tue 03.08.2021, 12:14
Tuga2112 wrote:surfboardfiller wrote:I just fitted a Bosch/02 Mercedes C Class W203 C220 2.2 CDI Auxiliary Water Pump 2038350064
thanks Phill.
ditto
"brakes are no good - they just slow you down" Fangio
by Tuga2112 » Sun 29.08.2021, 18:42
I Bought mine from Autodoc
It wasnt a perfect fit. but good enough for me, and i managed to install it without any problems.
Video here just before it goes live on saturday. (im posting here while its uploading so if you cant see it is because your reading this message too quickly.
by simonbuk » Thu 05.03.2026, 22:28
I just bought a new pump as the outlet pipes on my original were very oval !!
I watched Tugas video and I see that he had to extend the wiring. Although I haven't yet put my clam back on and work out where the wiring loom sits I managed to plug it in without problem.
I wouldn't have thought that there's a difference between SE and S2 looms is there ?
Black S2 No.357
Aqua Blue S2 No.385
simonbuk
- Location: Mostly Worthing,West Sussex, sometimes the canals.......
by Fredjohn » Fri 06.03.2026, 09:56
Simon
Did you buy the same pump as João?
Were the leads on the new pump the same length as those on the old one, or was the connection (plug) the same?
As the SE and S2 both share the same pump, my guess is that at least that part of the loom would be the same.
by Tuga2112 » Fri 06.03.2026, 13:34
as john mentioned.
the same compatible pump can be made with different lenghts of the wire plug. mine didnt have a wire at all, so i had the extend the car's harness
if you get one with a plug with about 10cm of wire that will be enough
Users browsing this forum: No registered users and 17 guests
