Car Battery
Car Battery
Postby Monty » Thu 18.12.2008, 00:14
Well my Battery is as dead as Dico`s Brain cells :lol:
Couldn`t find much reference on here and there`s not much in the handbook about size/dimensions.
The Orginal is a Delco 842
255A
Euro size L2 (which doesn`t help in choosing a Battery)
The one i`ve removed from mine was a Halfords 075
Halfords list ours as 065 & 075
http://www.halfords.com/webapp/wcs/stor ... sMMYS.y=10
the 065 & 075 size is 242x175x175mm
Another site list the M100 as 027 which is 242x175x190mm, so this battery is 15mm higher than the ones above.
http://www.tayna.co.uk/batterygroups/12 ... page1.html
Autoexpress did a review IIRC in 2007 http://www.autoexpress.co.uk/products/p ... eries.html
and Halfords came 2nd & 3rd, infact there standard battery did better than there Advanced calcium type.
The Halfords aren`t cheap ie £70 to £85, so did a search on the net and found a place more local that do cheaper price batteries
http://www.alpha-batteries.co.uk/
Lucas Classic 065/075
Specifications:
60ah
540cca
Silver Calcium Technolgy for Heavy use
Maintenance Free
4 Year Warranty
Dimensions:
242mm x 175mm x 175mm
£54.99 including postage
Also noticed that the same company has the batteries listed on ebay under 2 names at cheaper prices than there website.
http://cgi.ebay.co.uk/LUCAS-12v-CAR-BAT ... m153.l1262
anyways i went to pic the above battery from there shop and was told they haven`t got them in stock as there waiting for a shipment, so he did me an
AC DELCO TYPE 027
62AH
540 CCA
Calcium Technology
5 Year Warranty
for £38.99 :-D
http://cgi.ebay.co.uk/12V-AC-DELCO-TYPE ... m153.l1262
I can confirm that the higher 027 Battery will fit (even with Simons Roll Hoops fitted) but i wouldn`t go any higher lol:
Edit:-
Just incase the ebay links go dead, here`s the ebay sellers details
Sellers name:- lucasdirect
http://stores.ebay.co.uk/Lucas-batteries-direct
Sellers name:- alpha-products-man
http://stores.ebay.co.uk/THE-BATTERY-MANs-SHOP
Re: Car Battery
Postby dermotbell » Mon 22.12.2008, 18:04
Just fitted a Halfords Calcium battery last week, wish I had known it was outperformed by the standard. Could have saved myself £30. :cry:
Dermot Bell
dermotbell
Re: Car Battery
Postby Monty » Mon 22.12.2008, 20:46
dermotbell wrote:Just fitted a Halfords Calcium battery last week, wish I had known it was outperformed by the standard. Could have saved myself £30. :cry:
lol, the dead battery i pulled from the Elan was also Halfords Calcium and it`s listed as £85 :shock:
Re: Car Battery
Postby mnemonix » Tue 23.12.2008, 11:36
Put me down for one too (in there when i bought the car). It wasn't holding its charge so I considered changing it, saw the price :shock: and figured I'd give it another chance. The jury's out at the moment.
mnemonix
Re: Car Battery
Postby Sy V » Tue 23.12.2008, 11:59
Remember though, Halfrauds have a 3-year no questions asked return and replace policy.
Mind you, I wonder if they'll be in business in three years...
Re: Car Battery
Postby IANPARKIN » Tue 24.03.2009, 20:37
hi
has everyone got to much money .
the original delco battery is still available from a delco agent for £38
i had no problems sourcing one :lol:
IANPARKIN
Re: Car Battery
Postby chris.t » Tue 24.03.2009, 23:45
Well courtesy of Halfrauds gaurantee I'm on my 3rd battery from them. I can say in all honesty that they have failed literally a week or so before the gaurantee ran out. So i've had good value from my Halfrauds batteries. It really is a no questions asked gaurantee!
Re: Car Battery
Postby Adam » Wed 25.03.2009, 19:23
Personlly wouldn't touch a Halford's battery again as I've had several fail on me. Originally thought it may the car leaking current somewhere. In desparation I tried a spare Varta battery from an old Audi which was completely flat - a quick charge (with only a motorbike charger!) and it hasn't missed a beat in over a year.
Adam
Re: Car Battery
Postby lotos » Wed 25.11.2009, 17:20
Monty wrote:the 065 & 075 size is 242x175x175mm
Wow these are completely different than USA battery sizing... http://www.rtpnet.org/teaa/bcigroup.html
I've just been battery shopping and the 65 and 75 sizes here are HUGELY different! My car had a 26 in it (and only 525 CCA) which seems maybe undersized. It's only 15 months old but completely dead.
lotos
Re: Car Battery
Postby kenich » Wed 25.11.2009, 20:56
Sy V wrote:Remember though, Halfrauds have a 3-year no questions asked return and replace policy.
lol I hope they will be as I have lots with warrenty with them. I tend to use Halfords now just on the 3yr basis. Those Delco ones are cheap (and nasty), my not used very often track car went through 3 in a year to. The replacement halford one done the job fine for 2 years. Guess with some you get lucky :shock:
kenich
Re: Car Battery
Postby surfboardfiller » Wed 16.12.2009, 12:48
Halfords battery is a little wider than original equipment, the retaining bracket may need a little adjustment with a hammer to thin the bottom lip a little.
I'm not hugely impressed with the Halfords Calcium battery holding it's charge either. :?
surfboardfiller
Re: Car Battery
Postby theelanman » Wed 16.12.2009, 13:43
Im fitting a 'discarnect'......
I nearly always during the wet and wild months end up not using the elan because the moment the sun comes out is the moment I realise I forgot to put it on charge the day before....... :?
so Im gonna fit one of these for when I park it up in the garage.......Id say probably ideal if your going to keep leaving the car for a couple of weeks or more between starts.......
just a thought
cheers
G
http://www.amazon.co.uk/Richbrook-DIS-C ... B0019ULCPW
Re: Car Battery
Postby Gee0 » Thu 17.12.2009, 20:16
hi
I have just fitted one of these as my battery was only lasting a couple of weeks and dead every time I went to get her out for a run.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... _792wt_941
Fitted behind the drivers seat.
G
Gee0
Re: Car Battery
Postby lotos » Thu 17.12.2009, 22:01
That's a good idea - my negative battery cable already has a quick-disconnect on it, but I don't plan on utilizing it much since I bought the new Battery Tender for it.
lotos
Re: Car Battery
Postby MPx » Fri 18.12.2009, 00:29
Just a word of warning guys. Those devices are famous for corroding up the same way dry battery terminals do. Its another link in the high amp chain so another point that can cause poor starting. In addition you need to put the bypass link in if you want to maintain the alarm etc. so the battery still drains in 3 or 4 weeks. I prefer the battery conditioner solution using an Opitmate III or similar. Even when I kept a car in a garage without power I managed it on a solar panel. Jm2pw ...
Mike - MPx
95 M100 Elan S2 (423)
86 Turbo Esprit
MPx
Re: Car Battery
Postby VagueShot » Fri 18.12.2009, 09:48
Halfords fitted a new battery for me with no fuss eighteen months ago. It then failed this summer for no apparent reason and I went back and got a new free battery, which appears to be fine. I think the guarantee works from the date of the first battery though.
James Miller
http://anonw.wordpress.com/tag/lotus-elan/ - Ramblings of an anonymous widower and sometimes his ever-faithful Lotus Elan.
VagueShot
Re: Car Battery
Postby addict » Fri 18.12.2009, 22:35
mine came from gsf car parts and is a bosch item good price too
addict
Re: Car Battery
Postby Coupeboy » Wed 23.12.2009, 20:15
Somewhere else to try: http://www.tayna.co.uk/
1992 Elan Pacific Blue SE
2007 325se Coupe
Coupeboy
Re: Car Battery
Postby muley » Thu 24.12.2009, 12:59
..or here ...
£45 with 4 year guarantee
http://www.advancedbatterysupplies.co.uk/
Actually took 2 days but apart from that - fine
Have a good Xmas
1995 Palacio S2 no 507
Best Battery
Postby abmunro » Tue 13.05.2014, 11:56
I've searched for threads,
Any opinions on best battery
I have a 50 Ah battery currently dead...
abmunro
