recirculating coolant pump
Postby texas2201 » Sat 20.09.2014, 14:36
Mine had given up the ghost and it meant I had to leave the engine running while it cooled down - or it would vent through the expansion tank :-(
replacement was £00s from Lotus and only slightly less from other suppliers - so had a look on ebay and the Merc SLK recirculating pump looked very similar :-) £20 plus postage you say.........................OK I'll try it
Only thing you need is the plug from the loom from the original car and splice it onto the Lotus plug - hey presto it works great :-) Happy Bunny now
http://www.extremepetrolhead.blogspot.com/
Re: recirculating coolant pump
Postby HJ2 » Sat 20.09.2014, 14:59
:goodposting:
That's cheap as chips!
Postby epipete » Sat 20.09.2014, 19:32
Any SLK? Do you know which model or year?
Does it have a reference number which might be cross referenced to other Mercs?
Postby cliff » Sat 20.09.2014, 21:31
Bought my Merc pump from Amazon, a bit more expensive but does come with the plug. More importantly, the page lists a load of other Mercs that use the same pump. :)
http://www.amazon.com/0008356964-75-91- ... f_pe_p_t_2
Original thread
viewtopic.php?f=46&t=9465&start=40
Note that because of the plug, the pump sits 2 inches nearer to the center of the car.
91 Lotus Elan SE Turbo
07 Megane CC
06 Alfa Romeo Brera
cliff
Postby texas2201 » Sun 21.09.2014, 10:00
Cheers Cliff - when I did a search on the site it did not bring up that thread - it would have saved me some time if I had found that first - could the mods put it in the Wiki?
