Steering Rack Gaiter
Postby par » Fri 01.04.2016, 16:48
Does anyone have an alternative for replacement steering rack gaiters?
The multifit options from the local motor factors are a bit on the short side, there must be something similar from a mainstream model that would fit.
par
Re: Steering Rack Gaiter
Postby Brit-Car-Nut » Fri 01.04.2016, 17:50
I am assuming you are rebuilding a LATER car: the bellows diameter at the rack is 46mm.
B100H6031S is still available from Lotus at around £8.25 (Lotus raised their prices yesterday and the new price book isn't out yet). SJs still show them at £7.79 (yesterday's price)
SJs shows the older version A100H6031S (52mm) as available but at £45.05
HD Replacement Shift Cables and Short Shift Kits still available
HD Replacement Shift Cable and Short-Shift Kit prices
Download Manuals Here
Postby par » Fri 01.04.2016, 23:03
It is a 91 SE model I am rebuilding, I am almost sure the diameter of the rack is 52mm (battery has died on my vernier gauge).
Trying to avoid the set from SJ at over £50 if there is a suitable more cost effective option.
par
Postby Brit-Car-Nut » Fri 01.04.2016, 23:56
It is not the diameter of the rack, just where the two gaiters mount. The 1991 FED car is 46mm.
Postby Jamie N » Sun 03.04.2016, 09:42
Gauranteed there will be something in the big yard Steven, if you find a pair that fits, in good enough condition to last a couple of years, and are 1 quid each, then its a no-brainer surely!. :wink: Text me the inner and outer diameter and overall length and i will have a look for you if you want.
Jamie N
Seal Wrangler
Postby par » Mon 04.04.2016, 14:06
That would be great Jamie, I have an old perished one I can drop off to you which might be easier.
par
Postby Jamie N » Thu 07.04.2016, 21:06
2 Gaiters here for you Steven, look to be a good fit and good as new, and the best bit..... free gratis and for nothing!. 8)
Jamie N
Seal Wrangler
Postby par » Fri 08.04.2016, 11:10
Jamie N wrote:2 Gaiters here for you Steven, look to be a good fit and good as new, and the best bit..... free gratis and for nothing!. 8)
Thats great Jamie will pick them up over the weekend.
Any discount on the free gratis ;-)
par
