by Oliver » Sun 20.03.2005, 22:32
Possibly a bit trivial but the current Honda Civic diesel (1.7 CTDi) has an Isuzu based engine & i have found that the sump plug and washer appear identical to that fitted to the Elan.
M100 N/A - No PAS
RenautSport Megane 275 Cup
MGF
Benelli 2C
Oliver
by ailwyn » Fri 06.01.2006, 23:18
Is the sump plug washer a dealer part or are there any additional substitutes as I cant seem to get a washer for the Elan or the Civic CTDi from local suppliers?
Ailwyn
- Forum Member
by Dico » Fri 06.01.2006, 23:32
Monty got me a couple, from SJ's i believe.
Although i would be suprised if they can't be matched up.
- Fool Boy Four - Founder
by John_W » Sun 08.01.2006, 16:22
Halfords HSP605 "Sump Nut and Washer Kit" fits. I've just changed my oil and tried the bolt for fit of the thread. 22mm spanner for the bolt head, same as original.
The copper washers seem to vary. The one I have on the car is fairly broad (ie the width of the metal between the inner hole and outer edge) whereas the spare I got from SJ is fairly narrow; the Halfrauds HSP605 has a washer which is in between the other two. I suppose that so long as it's copper and the hole diameter is OK you're laughing.
- Heid-bummer
by Oliver » Thu 19.01.2006, 20:34
I`ll get the Honda part numbers from work tomorrow.
Oliver
by Oliver » Mon 23.01.2006, 20:52
Honda part nos:
sump plug 90013-PLZ-D00
washer 90413-PLZ-D00
Oliver
by Coupeboy » Thu 10.09.2009, 22:15
Lotus part number is A100E6159S 'Washer-Sump Drain Plug' which is 14mm x 20mm x 1.5mm (I/D x O/D x thickness).
It should be possible to match this size in a hardware store or available from CPC in a bag of 50 for approximately £6 that’s 12p each. Cheaper than Halfords at £1.22 or Paul Matty at £1.48 each! Mind you that’s 250 000 miles of oil changes!
1992 Elan Pacific Blue SE
2007 325se Coupe
Coupeboy
by GeoffSmith » Thu 10.09.2009, 23:06
Some of this info added to the
Wiki.
- Kitty Fiddler
