Thermostat / Isuzu
Thermostat / Isuzu
Postby DAdragna » Wed 07.12.2005, 03:57
Does anyone know the Isuzu thermostat that will work in our car?
What Isuzu car is it from, or what specific motor? I saw it somewhere on this list and wrote the number down, but the auto part store said the number I had was not a correct part number!? :shock:
Thanks,
Dan A
DAdragna
Postby Doc Fizzix » Wed 07.12.2005, 04:24
Isuzu Impulse RS (turbo) 1991-1992 4XE1-T
I thouught they come in two different temperature ranges, if I remember right. Check the one you are taking out of the car and it should have a temp marking on it.
Doc Fizzix
Postby DAdragna » Wed 07.12.2005, 04:41
Thanks M100,
I appreciate the info. There is so much info on this forum...I have just been looking and looking. Pretty fun though! :D
Dan A
DAdragna
Postby Doug » Wed 07.12.2005, 09:58
Postby DAdragna » Wed 07.12.2005, 14:18
Doug,
Thanks for the link. I am not real tech savy! :D I was wondering if there is a search engine for the forum that I am not seeing?
Thanks,
Dan A
DAdragna
Postby John_W » Wed 07.12.2005, 20:50
DAdragna wrote:I was wondering if there is a search engine for the forum that I am not seeing?
Dan,
at the top of the page are 7 items:
FAQ  |  Search  |  Memberlist  |  Usergroups  |  Profile  |  You have no new messages  |  Log out
Try the second one.
John :wink:
Postby stevo » Thu 08.12.2005, 12:36
is this the temp sensor A100E6357S? if so i think i need one.
stevo
Postby ab2cv » Sat 10.12.2005, 11:42
I've decided I need to replace my themostat too. Is there a part number or manufacturer cross reference for a vehicle in the UK so i could walk into a local motor factor or halfrauds and pick one up rather than having to order from SJS or the likes?
Alan
Yellow Esprit GT3
ab2cv
Postby WillB » Tue 07.02.2006, 01:11
Ooops., very late on this but can confirm the UK Izuzu Piazza Turbo has the same thermostat as the Elan. Approx £8 from motor factors
WillB
Themostat
Postby NickHawk » Tue 04.07.2006, 19:25
Hi
Hope this helps.
Quinton Hazell part ref no is: QTH102K and about £6 from any good motor factors.
EDIT by Geoff 15th June 2008: While the QTH102K fits, it is an 88°C thermostat. Your temperature gauge may sit at the more traditional position of approximately half way up the dial but the engine is running too hot. It should be replaced with QTH100K which is an 82°C 'stat.
Silver M100 SE - Still For Sale sort of!
NickHawk
Postby mickmick » Mon 15.01.2007, 15:13
the thermostat is indeed an isuzu piazza one
i got mine from halfords for about 6 quid including a gasket kit
the halfords part number is HTK602
now i have one, i just want to keep tinkering with it!!!!!!!
sorry mum :(
mickmick
Postby WillB » Mon 15.01.2007, 15:27
WillB
Postby DeeAitch » Sat 17.02.2007, 22:02
Bit the Bullet today and tackled the Thermostat :D seing as I have the system drained for a new water pump.
However the old 'stat differs from the Halfords one - it is an 'eccentric' design with a rubber seal and a vent whereas the Halfords one is concentric with no vent :?
Not sure if the old one (left on the pic) is a genuine part or not but it is the right temp rating. The Halfords one fits OK but do we need the eccentric with vent type?
Thoughts please, before I put it back together!
DeeAitch
Postby dapinky » Sat 17.02.2007, 23:23
Can't really comment on the Halfrauds one, as I never got mine from there.
All I can say is that the Gates ones i sourced from USA are identical to the OE ones (ie eccentric with the vent, rated at 180 degrees).
I believe WillB has used the Halfords one, as has Paul Watkins (assuming it's the same one you have) without any problems.
Postby Enright » Sun 18.02.2007, 22:37
I put a Halfords one in and it's worked fine ever since.
Better in fact.
It warms up quicker. You can feel it through the heater.
Which means I should be getting better economy.
Postby mickmick » Sun 18.02.2007, 22:37
i got the halfrd one in, car has never run better
sorry mum :(
mickmick
Postby DeeAitch » Fri 23.02.2007, 19:35
Thanks for the reasurance guys.
A closer inspection of the Halfords unit revealed a small v shaped vent - you can just see it in the RH pic above. This means the 'stat is never fully shut off but is more in line with the OE one so I'm a bit happier :P Enough to fit the bugga anyway :-)
DeeAitch
