Sump from Isuzu??
Sump from Isuzu??
Postby donsladek » Sun 07.05.2006, 05:08
Is the sump from the US turbo Isuzu Impulse a direct replacement for the Elan sump? Might be easier to find...
Thanks!
Don Sladek
Don Sladek
Calypso Red '91 #37594
donsladek
Postby Specky » Thu 03.01.2008, 23:40
Bump..
A100E6330S Lotus sump £123... :shock:
Is ours shapped to go round the Pongy Thingy?
Postby Specky » Fri 04.01.2008, 01:53
Does this look right...
Clicky
Follow the Mechanical Parts Catalog...
Anyone know of a PT No...
Postby GeoffSmith » Fri 04.01.2008, 09:19
Looks pretty adjacent to me apart from the shape at the bottom - cutout for the oil pickup?
Postby Specky » Fri 04.01.2008, 17:58
if anyone has a sump/pan could they photograph it please...
extermal and internal view please...
just so I can match it....
Postby lotusgirlmarie » Fri 04.01.2008, 21:41
Bottom line..... The Isuzu sump fits. I have one on my car.
lotusgirlmarie
Goddess
Postby donsladek » Sat 05.01.2008, 17:36
lotusgirlmarie wrote:Bottom line..... The Isuzu sump fits. I have one on my car.
Thank for verifying this :lol:
Now I've got another to-do on my car! :roll:
Don Sladek
Don Sladek
donsladek
Postby donsladek » Sat 05.01.2008, 17:49
Here's a used Isuzu sump on eBay if anyone is interested, includes picture from top, info on part numbers, applications, etc. No bottom pix, though - maybe it's dented??
eBay Isuzu 1.6L Sump
From the posting:
You are viewing a oil pan off a 1991 Isuzu Stylus with manual transmission and 1.6L DOHC motor. Manufacture date 11/1990. It will also fit:
91 Impulse
92 Impulse turbocharged
91 Storm
'92 - 93 Storm SOHC
91 Stylus from 7/90
92 Stylus SOHC
93 Stylus
This oil pan is manufactured by Tokyo Radiator Mfg. Co. and their part number is: 053551
Isuzu Part Number: 897031-0190
Please check with your local dealer to make sure you are buying the right part.
Don Sladek
Don Sladek
donsladek
Postby nitroman » Mon 07.01.2008, 05:26
I've been meaning to buy a suitably polished drain bolt!
nitroman
Postby Specky » Mon 07.01.2008, 19:52
Very nice... :-D
Lotus or Isuzu... If that makes sence.. :smt017
Any chance of a pic of the internal for the Wiki please...
Postby Doug » Thu 10.01.2008, 05:47
Nitro, I assume that dent is covered by the lower baffle or you would have bumped it out already?
beautiful beer pitcher you have there :wink:
Postby nitroman » Fri 11.01.2008, 02:26
In the lower left? That's done by the press when the pan is made. (I do have another pan I can dig out, but I'm almost certain of that)
nitroman
Postby nitroman » Mon 25.02.2008, 02:31
Here's the inside of the oil pan I took off the red car. You can compare it to see if you think the Isuzu one will work. BTW the indention mentioned is identical (you can see it pushed-up in the photo's upper-left. So it's not a dent.
nitroman
Postby nitroman » Mon 25.02.2008, 02:41
Here's the inside of the Isuzu pan on Ebay from the 06-Jan post. You can see several differences on both sides of the pan. Thought it best to grab this shot before the Ebay add disappeared.
nitroman
Postby GeoffSmith » Mon 25.02.2008, 07:42
Why is the internal plate a mirror image though? :smt017
Postby Specky » Mon 25.02.2008, 11:09
Just for ease of comparrison....
and I thhink we have a winner...
But there something in my mind LGM had to Mod part of hers..
Postby Specky » Mon 25.02.2008, 11:24
nitroman wrote:Here's the inside of the Isuzu pan on Ebay from the 06-Jan post. You can see several differences on both sides of the pan. Thought it best to grab this shot before the Ebay add disappeared.
and the ebay fella reversed it, instead of rotating it....
:smt036 :smt044 :smt043 :smt042
LMAO
Re: Sump from Isuzu??
Postby Specky » Wed 09.09.2009, 18:48
We've done a bit more work on the sump identiforcation, I now have 4 Pt No's including a GM Pt No, these are slightly different to the affore mentioned No's thou.(Including the Wiki)
I now have a new Isuzu sump to compare directly to the Lotus sump... :-D
I just hope we have a winner,
Sadly there may not be many more new ones left in the US,
Hopefully I can take that warning off the Wiki soon... :roll:
Finally has anyone got an Isuzu sump 8970310190 fitted? (As mentioned earlier in the thread)
It's not the one I have, but it may present more options...
Postby donsladek » Wed 09.09.2009, 20:37
I've installed a new Isuzu 8-97031018-0 sump, and it is the same as the OEM sump I removed (less the dents at the bottom :lol: ). The new sump has a Tokyo Radiator Mfg Co. label with P/n 870310180, andf what appears to be a serial number. I bought it on eBay ($50 USD!)and it was advertised for a 91-93 Geo Storm.
Don Sladek
donsladek
Postby Specky » Wed 09.09.2009, 21:06
Bingo !!! :-D
You have the same as me, and the same Pt No's :D
So that's confirmed, 60 odd squid new against 120 odd squid new
Must change that Wiki... :roll:
