replacing clutch tips?
Drivetrain problems
Postby Dico » Fri 22.06.2007, 11:52
I'm with stupid :-)
Stick with the stock clutch Alan.
Make sure you replace the drained gearbox oil with Redline MTL. You need two 1litre bottles (box takes 1.9 litres), available from Deemon Tweeks (spell check?). Comes to around thirty odd quid with postage, but worth it, and thats sorted for 60,000 miles iirc.
In effect your geting the labour thrown in for nowt for the oil change! Feel better now? :lol:
Postby ab2cv » Fri 22.06.2007, 12:39
Dico wrote:I'm with stupid :-)
Standard clutch ordered from SJS. :-)
Dico wrote:
Make sure you replace the drained gearbox oil with Redline MTL. You need two 1litre bottles (box takes 1.9 litres), available from Demon Tweeks (spell check?). Comes to around thirty odd quid with postage, but worth it, and thats sorted for 60,000 miles iirc.
:shock: So you mean the gearbox oil needs replacing at the same time? Best dig out the wallet again then :roll:
Seriously though, sounds like a good idea to replace it regardless. ..and I'll say to Kenny about the raft / prongeron when I'm booking it in. Thanks for the advice guys.
Alan
ab2cv
