Drivetrain problems
by Coupeboy » Thu 30.04.2009, 13:08
Since I've owned my car (2 000 miles) I've noticed that when braking in reverse that there is a noticeable (felt through steering and audible) clunking from the front end. It's been getting worse (possibly depending on how hard I brake). I investigated and found that the nearside caliper has a bit of wobble in it so have bought some new sliders but nearly enough to explain what feels like back lash in the drivetrain. I had a waggle of the RH (offside) driveshaft - the long one that seems to be supported mid way by a bearing thingy from the gearbox and found a lot of axial movement at the joint (inboard CV?) - possibly where the 'backlask' is occuring. Checking on the 'Lotus60thanniversary' link for sale part prices I can get a RH driveshaft for £100 ish instead of £360
. Has anybody experienced a similar symptom and come to the conclusion that it's the driveshaft? I'm assuming that at 100k miles this is an original part on mine.
1992 Elan Pacific Blue SE
2007 325se Coupe
Coupeboy
by Gordon » Thu 30.04.2009, 16:36
Could be any number of things I guess, but when mine started doing this, it was the rear engine mount!!
The long arm one that goes into the chassis - all the mounting bolts to the backbone were loose - took ages to find
Gordon.
1990 M100, Calypso Red
2005 Vectra C....
Gordon
by Coupeboy » Thu 30.04.2009, 19:55
Thanks Gordon. Will check out the mount first before spending any money. Hard to imagine that the engine 'rotates' much but I suspose a number of worn parts could stack up to movement. I was trying to canvass responses to the robustnesss of CV joints/driveshafts but despite the 'claim' on HonestJohn.co.uk that these take a hammering and fail often, judging by the response so far, these don't appear to be any more problematic than any other car.
2007 325se Coupe
Coupeboy
by Here Welsh Tree Rot » Thu 30.04.2009, 20:53
Engine mounts would be the first place I'd check to.
Lots of torque in a transverse engine setup.
mae o'n siared trwy ei het.
Dwi a 'n fawr bloneg Cymraeg bastai bwytawr
Here Welsh Tree Rot
