by dapinky » Fri 11.07.2008, 22:41
I used a special tool to fit mine - it's the outer race from a Megane Rear wheel bearing, which just happens to be a perfect fit as a drift - that and a BFH worked okay - it did take a bit of head scratching to work it out (and yes, i tried most of the other published results with varying degrees of success before i found a suitable drift tool)
The nearest i came to a successful attempt was using a thin piece of wood as a drift to get it located, then an old 10" extension socket bar as a drift , tapping it all round the edge.
It ain't an easy job due to the reduction in access as per everything on the car, but it is achievable.
One point worth a mention is to ensure that when re-fitting the driveshaft, locate it properly with a good shove for the final bit to get the circlip into the groove. It will fit without being fully located due to the 'slack' in the CV joint, but firstly, it will (may?) fall out whilst driving, and secondly, if it isn't pushed all the way in, oil will leak out due to the 'stepped' diameter design of the shaft.
