by dapinky » Tue 27.06.2023, 09:07
This is a picture of a Vauxhall Cavalier CV joint of the same era - the spring clips look like pretty standard circlips in shape, but with a constant section for it's entire circumference, and a square section......
...... I haven't seen inside an Elan one for a long time, and can't comment if the shaft groove would accept a square section clip or not - but as the CV joint is the same as a Cavalier one, it may well be the same (but I accept that they made different versions of the same CV joint, so may have adapted one for the Elan use).
