addict wrote:would this allow for a short shift at the lever end of the cables ?
bobbrown wrote:Works fine with Dave's short shift as the prototype had one fitted.
Denny wrote:I would also be interested to know if these work with the AB shortshift?
bobbrown wrote:With the AB short shift there is only one area that needs looking at and that is the pin on the cross gate gearbox end as this is a relatively short pin it is too short to get a rod end on as the bush is only about 8mm thick with a washer on it so say total to the R clip 8.5mm and it is welded in.
A 8mm rod end is 12mm so may be part can be made with a bush in it as this one is not as critical in terms or misalignment as the main selector which does move in and out as well as left to right.
Or the pin could be drilled out and replaced with suitable pin would prefer the latter as this then allows for misalignment.
Denny wrote:bobbrown wrote:With the AB short shift there is only one area that needs looking at and that is the pin on the cross gate gearbox end as this is a relatively short pin it is too short to get a rod end on as the bush is only about 8mm thick with a washer on it so say total to the R clip 8.5mm and it is welded in.
Bob,
Is it correct to say that the major problem with the AB cables is associated with the main selector cable?
If so could I just change the main selector cable for your super cable (nice work by the way) and keep the AB bracket, cross gate cable and short shift?
I have not fitted my AB set up yet so I could send them to you if required.
Much appreciated, Denny.
Specky wrote:The AB bracket is not suitable for Bob's cables, the diameter of the holes on the AB bracket are to small.
Tannerman wrote:Hi Bob, i sent a PM yesterday but i am unsure it has gone as there is nothing in my sent box....Tried again this am and nothing
lotos wrote:Of course this comes up after I buy AB Cables but before I install them![]()
