Driveshaft inner CV tripod replacements
Re: Driveshaft inner CV tripod replacements
Postby Simon_P » Sat 06.04.2024, 20:22
I am on FB as little as possible.
Can you post a link here.
The tulip wears on a patch where the rollers go this should appear as a small polished area. If the surface is breaking up it is worn out. Or the needle bearing can suffer in the same way. Worn splines will show a step.
