when i change my cables they were slightly stiffer than stock, but eased off with use. It does sound like u`rs aren`t adjusted correctly.
Sorry i can`t be off more help
Doc Fizzix wrote:If the shifting was good before the switch then I suggest that the cables are the cause. I find it had to belive that you could have damaged the gearbox just by switching the cables.
Have your tried the suggestion I gave above?
I suggest you try to re-attach the cales, remove both ends of the cables and then re-attach switching the side of the busshing facing the gear shift lever.
valimar wrote:Hi Everybody,
Endly I found some time to try what "Doc Fizzix" sugested, that means to change the fixing position of the crossgate cable, by the gearlever mechanism bracket. Only it seems to me not possible because there is only one way to fix it, unless one modifies the abutment.
Specky wrote:Secondly... The fore and aft movement is lovely,but sideways it's stiff, Would this be due to the above or another reason...(I have nothing connected at the other end, not even the bracket
