You said...
"A short-shift kit designed for SE cables will not work correctly with my cable kit since I use spherical bearing attachments while the SE cables us a simple bushing. "
"Honestly, it would be best to get the heavy duty, spherical ended cables and the matching short shift kit,"
Both these lead me to believe you were recommending I update some other cables in addition to the short shift. So I thought you meant the plastic housing and the associated cable I photoed earlier..
