Jackshaft Bearings
Re: Jackshaft Bearings
Postby Turners » Wed 20.05.2009, 10:00
The company that pressed out my jackshaft bearing are an agent for Hardy Spicer and he thinks he can refurbish the drive sharfts, Both the new shafts from Lotus came in Hardy Spicer boxes.
When I am up and about I will take him an old shaft to look at
My understanding is you can order the seals just from the 3 numbers
Turners
Postby Specky » Wed 08.12.2010, 16:55
Has anyone got an idiot guide on how to undertake this little task please. :poke:
I'm gonna do mine, but I don't want to damage it... :(
No one on the thread seems to have actually done it,
So I've taken some "man the fcuk up" pills....I have the shaft out and in my hands...I'm ready to start... :lol:
Hoping some one out there can help.
Postby Gordon » Wed 08.12.2010, 17:15
Specky wrote:Has anyone got an idiot guide on how to undertake this little task please. :poke:
I've still not plucked up the courage to do mine! - it's either that or the leaking petrol tank next... :roll:
1990 M100, Calypso Red
2005 Vectra C....
Gordon
Postby GeoffSmith » Wed 08.12.2010, 18:15
Dave, try Dave Hall or Alan (deeaitch and ESM).
Postby Specky » Wed 08.12.2010, 18:59
Just bought this to confirm the dimensions for your Wiki thread.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 3D1&_rdc=1
But when it comes to getting a bearing for fittment, I don't know which one to get :?
Normal, rubber sealed, stainless steel sealed, One with a bearing which has larger internal radial clearances for high temperatures
May be the old bearing will have some secrets
Cheers Geoffers, I'm just going out to the work shop now to have a go a stage one...
Postby Specky » Wed 08.12.2010, 19:39
vesuvius mission success.
Just did stage one....
and it's scarily easy, I'll post pics shortly.
And Matt, I know how the damaged yours... clowns.. :banghead:
Postby Specky » Wed 08.12.2010, 20:05
Here's what I've done so far...
i) Remove jack shaft and R/H drive shaft from the car as an assembly
ii) Split them
iii) Removed the circlip from the end of the drive shaft (just for clearance)
iv) Used a three legged hub puller, making sure it won't catch the metal dust guard when the shaft is pressed out, I used a bench vice on the mating face of the bearing housing, not as shown in the picture. I was just setting the puller up when I took the picture).
v) and it comes out
I'll complete stage 2 later
and stage three when I have a bearing
Postby Monty » Wed 08.12.2010, 20:26
Specky wrote:
I've taken some "man the fcuk up" pills....N
LMAO :lol:
Have you got some for Dico :-D
Nice work SpeckOmaestro :clap:
Postby bobbrown » Wed 08.12.2010, 20:47
Would not be worth fitting a cheap bearing as these bearings in a good make are not expensive so I would go for a SKF bearing, probably SKF 62062RS1C3 as I doubt it is anything that special.
Is there any markings/numbers on the seals?
Pacific Blue N/A
Postby Specky » Wed 08.12.2010, 20:50
i) Remove the jack shaft and the R/H drive shaft from the car as an assembly
ii) Split them
iv) Use a three legged hub puller, making sure it won't catch the metal dust guard when the shaft is pressed out
v) and the shaft comes out
vi) Remove the dust covers
vii) Remove circlip
viii) Press out the bearing
ix) Refitting a new bearing is simply the reverse :lol:
Postby Specky » Wed 08.12.2010, 20:51
bobbrown wrote:Would not be worth fitting a cheap bearing as these bearings in a good make are not expensive so I would go for a SKF bearing, probably SKF 62062RS1C3 as I doubt it is anything that special.
Yep, back in 5
Postby Specky » Wed 08.12.2010, 20:55
Japan
NTN
6206 LU
TMB EXI
RUBBER SEAL
Postby Specky » Wed 08.12.2010, 20:59
Just thought Bob... Why did you go for the C3 and not the standard...
I nearly bought that exact one, then bottled it. I thought I'd get a cheapy and check dimensions etc first.
Postby Specky » Wed 08.12.2010, 21:01
Monty wrote:
LMAO :lol:
Only if someone started a group buy... :lol:
Postby GeoffSmith » Wed 08.12.2010, 21:13
Specky wrote:TMB
It's either your bad eyesight or your crap photograph (either way, it looks like you should have gone to SpeckSavers), but it looks like THB to me. :lol:
Postby Specky » Wed 08.12.2010, 21:21
and that's why you wear the gigs... :lol:
Postby bobbrown » Wed 08.12.2010, 22:21
Specky wrote:Just thought Bob... Why did you go for the C3 and not the standard...
Should have said SKF 62062RS1 as they do not need to be C3 as they are for hot and high speed environments.
Cheapy! no need as it would be a waste of money and a SKF 62062RS1 is only £10.38 inc VAT and delivery.
So no numbers on the seals?
dimensions?
Pacific Blue N/A
Postby Gordon » Wed 08.12.2010, 22:26
Well done that man ;)
How much interference/pressure is needed to put the jackshaft back into the new centre race?
Obviously, having gone this far, the last thing you want to do is damage the new bearing...
Gordon
2005 Vectra C....
Gordon
Postby Specky » Wed 08.12.2010, 22:28
dimensions?
Try here :lol:
No dimensions yet as I haven't pressed it out.
Just thought... do you mean the dust seals as oppossed to the bearing seals
BIG ONE
NOK
19Z 36 62 8
6 (TOTALLY RANDOM, NOT WITH THE ABOVE)
LITTLE ONE
NOK
19Z 43 56 9
30
Postby Specky » Wed 08.12.2010, 22:32
Gordon wrote:Well done that man ;)
Gordon
No idea... I haven't got the bearing yet...
