Monty wrote:Very strange, wonder could it be a clutch problem![]()
The only problem i've had is the gear stick doesn't spring back to the centre but i can't remember if it did or not before i fitted the AB cablesDico did his and his does spring back to the centre.
Elanlover wrote:If you have a helper, park the car and pop the hood (bonnet). Have your helper move the gear shift around while you watch how the levers move to see if there's anything in the way, etc. Have a look at the clutch cable movement too. Maybe its still in need of some adjustments or maybe its what Monty has suggested. Might as well eliminate the relatively inexpensive before going on to the expensive problem possibilities...........
Not another shifter and in only 6 weeks
Dave wrote:Must learn how to do that 'here' thing
