Here's the first problem:
I just installed new AB shift cables. I had to have a machine shop modify the bracket that came with them because the cross-gate cable went through it pointed in the wrong direction. That part of the bracket had to be angled so the cable pointed a bit more toward the front of the car, otherwise I couldn't move the shifter side-to-side at all because the cable was binding. I think maybe a previous owner made a custom short-shift modification or something. The bracket that was in the car with the OEM cables had been modified, too. (see pic) Anyway, after that the cable goes through straight, but the shifter doesn't self-center like it should, and it takes more force in the side-to-side movement than it should. It makes third gear difficult to find. Any thoughts on what could be causing this? Would it cause this if the cables were twisted in the tunnel? I'd rather not have to take everything apart again, but I have to fix it.
Another possibility could be that I damaged something. The cable end (gearbox end) of the cross-gate cable was a very tight fit over the shaft it goes on. I tried gently tapping on it in an attempt to get it on (which didn't work) until I finally managed to get a spanner on there and squeeze it down. I know I didn't squeeze on anything that could be a problem, but could I have hurt it tapping on it?
The second problem I'm having (and this wasn't happening before the cable change) is with the turbo. My test drives to see how the shift cables were working revealed the turbo problem. At the point where the turbo should kick in, all I get is some noise (which seems to indicate it's turning), which I can't think of the right words to describe, and the boost gauge shows nothing. I think the needle did flicker a little once. I also feel no boost. I know nothing at all about turbos and could really use some help.
(sorry couldn't resist--hope I didn't arouse anyone/Gary) you can clean the inside of it too with your favorite solution and a lot of shaking too while at it!
