by classicaitalia » Tue 08.12.2009, 11:07
Have my M100 stored for winter on starting it today tried to drive forward no 1st,3rd,5th gear selectable just a floppy stick where they should be - 2nd,4th and reverse OK. As I am in Italy 170km from a Lotus Dealer any clues as what it may be so I can tell the local mechanic, and get necessary parts ordered ?
Lotus ElanM100,'75 Alfa Romeo Spider Duetto,Classic Mini CooperS,Discovery 4.0,Pajero LWB V6.
classicaitalia
by theelanman » Tue 08.12.2009, 11:18
gear cables?........sounds like your plastic has given up .....
search AB cables.........willb usually has some......
there is a temp fix with a couple of cable ties which will allow you to use the car a little.....but I wouldnt rely on it for too long......
cheers
G
by theelanman » Tue 08.12.2009, 11:21
by classicaitalia » Tue 08.12.2009, 11:46
Thanks - I will get new cables ordered and sent out here - at least the mechanics here are used to Lamborghinis (tractors that is)
classicaitalia
by VagueShot » Wed 09.12.2009, 12:26
I've got this problem now. I'm actually in Holland, as it went wrong on the way to the boat, so as I was visiting a friend a few kilometres the other site I chanced it. Drove well in 2nd, 4th and Reverse, but then it was only local roads. Would you chance it back or get it fixed over here provided I can get the cables. There is a Lotus service place in Delft, which is not far away.
VagueShot
- Tinkerer
by classicaitalia » Wed 09.12.2009, 17:22
Drove mine to garage only about 7km this morning - not enjoyable.
Worth trying a local mechanic in case there is a quick fix - a clip slipped or something.
classicaitalia
by HJ2 » Wed 09.12.2009, 18:51
Hey!
I'm from Delft!
If you need anything or a place to stay, just say the word an we'll work something out!
Got a well equiped garage as well, and, unfortunately, lot's of gearcable change experience as well...
PM me, I'll give you my number.
by John_W » Thu 10.12.2009, 18:02
classicaitalia wrote:Drove mine to garage only about 7km this morning - not enjoyable.
classicaitalia,
Have a look
here for a fix which might save you buying new cables, or at least get you back on teh road until the new ones arrive.
- Heid-bummer
by classicaitalia » Fri 11.12.2009, 14:44
John_W wrote:classicaitalia wrote:Drove mine to garage only about 7km this morning - not enjoyable.
classicaitalia,
Have a look
Thanks car in local garage and new cables on their way to Italy
classicaitalia
by VagueShot » Sun 13.12.2009, 10:18
Home in Suffolk now after a pleasant drive through the villages. Hook-Harwich Ferry was no problem, except that they delay you for two hours, so they can sell you breakfast.
Now to get the cables and get the garage to fit them. They're only two miles away!
Has anybody got the phone number for AB Cables in the UK?
TIA.
James
P.S. The Elan is on my blog at
http://anonw.wordpress.com.
VagueShot
- Tinkerer
by HJ2 » Sun 13.12.2009, 20:28
I see, so is mine !
by theelanman » Sun 13.12.2009, 20:45
you'll need to drop WillB an email or PM.......hes the source for the AB bits.....
cheers
G
by Denny » Mon 14.12.2009, 08:38
I got mine directly from Alan Betts who is a member of this Forum.
They were delivered within a week including the bank transfer and went straight through customs with no extra charge.
I will PM you his direct email.
Denny
by rip » Mon 14.12.2009, 10:19
VagueShot wrote:Now to get the cables and get the garage to fit them. They're only two miles away!
Newmarket?
GST Performance @ Studands?
Few know the Elan better than Gerald
by classicaitalia » Sat 19.12.2009, 11:03
theelanman wrote:you'll need to drop WillB an email or PM.......hes the source for the AB bits.....
cheers
G
I emailed WillB for cables but got no response, I may have had wrong email address for him, so I got mine diectly from Alan Betts.
classicaitalia
by VagueShot » Sat 19.12.2009, 12:06
All sorted now by Gerald. Just been driving it around in the snow. New cables are on order.
VagueShot
- Tinkerer
