by superbad » Wed 03.11.2010, 01:40
My clutch engagement point has recently moved closer to the firewall, and I need to depress the pedal hard to fully release the clutch. In addition, the pedal is squishy/sloppy at the top of travel, and doesn't return to its correct rest position. Clutch engagement is fine. Seems like a stretched/fraying clutch cable to me, could it be something else? And how difficult is it to replace?
superbad
by HJ2 » Wed 03.11.2010, 10:34
Did you try to adjust the cable?
You can do this @ the engine end of the cable. The clutchcable hooks up to the clutch lever with an adjuster...
by superbad » Wed 03.11.2010, 13:20
Was going to try today. I don't have a very good spot to work on cars at the moment.
superbad
by HJ2 » Wed 03.11.2010, 13:28
Pop the bonnet and reach in with the correct spanner (22?)
No space needed and done in 2 minutes
by superbad » Wed 03.11.2010, 17:59
That's easy to get to, I thought it was underneath. And to answer my own question, yes, the plastic thread has separated from the cable jacket.
superbad
by dapinky » Wed 03.11.2010, 18:27
superbad wrote:Was going to try today. I don't have a very good spot to work on cars at the moment.
I bet your workspace is better than the muddy gravel layby i ended up changing mine in a few weeks ago (stuck just outside Hereford and getting dark!)
- LEC Administrator
