Gearbox and clutch removal/maintenance tips
Postby Alan Head » Fri 26.07.2013, 19:16
I've had my Elan for a couple of years and now plan to do some work on the gearbox.
I find that the synchromesh on 3rd gear is not as good as I would like. It's not too bad but a miss-timed gear change can cause an occasional crunch.
The previous owner, John (M100 TWO) has done a great job of maintaining the car so I suspect it is time to buy a new 3rd, 4th synchro assembly.
I plan to purchase the following :-
3rd, 4th gear synchro assembly
Gearbox cover plate gasket
Driveshaft seals
Driveshaft seal insertion tool
Silkolene Pro SRG75
Is there anything else I should buy to do the job ?
Any tips on removing the gearbox from the car ?
Any tips on removing 3rd / 4th gear shaft ?
Alan
Alan Head
Re: Planning some gearbox maintenance over winter.
Postby Alan Head » Tue 22.10.2013, 20:35
My Elan gearbox has now been rebuilt and is back in car.
I removed the gearbox then took it to Alan Voigt to perform the rebuild.
The box has new baulk rings for 3rd and 4th gear. Everything else inside the box was in good condition but I had all seals and gaskets replaced as well.
I put the gearbox back in the car last weekend.
The car now drives great with fast smooth quiet gearchanges. :D :D :D
I'll post details of the job once I sort out the photos. It was not easy to get good pictures but it should give a reasonable guide to getting the box out of the car.
Alan Head
Postby Alan Head » Tue 22.10.2013, 21:28
1. Start by jacking up car, removing front wheels, pop out wheel centres, put wheels back on and loosen drive shaft nuts.
2. Jack up car, remove front wheel, place another jack at the inner jacking point at the rear of the prongeron and raise the car.
3. Now put car on axle stands at normal front jacking points. I have also placed a block of wood under the sills just in case!
4. Now open the bonnet and remove the air filter and associated pipe work
5. Remove the clutch cable from the clutch lever. At this point it is also worth removing the bolt that holds on the expansion bottle.
6.Remove the clutch cable from the guide bracket.
7. Remove the spring clip from the smaller of the two gear selector cables and pop off the cable.
8. Remove the spring clip from the larger gear selector cable.
9. Pop off the larger gear selector cable from its pin.
10. Remove the speedo cable by removing the 10mm nut and clamp plate.
Alan Head
Postby RayD » Tue 22.10.2013, 21:41
Excellent job Alan,
Thanks for going to the trouble with the pictures.
Postby Alan Head » Tue 22.10.2013, 22:01
11. Remove the three bolts that hold on the gear selector cable mounting bracket. This avoids accidently adjusting the cable lengths.
12. Disconnect the wiring from the reversing light switch.
Its now time to work under the car.
13. Drain the gearbox oil by removing the drain plug.
14. Unbolt the top wishbone ball joint. Take note of how many shims are placed in front of and behind the balljoint. there should be 8 shims in total for each ball joint. In my car there are also inserts to set the camber. Remove the brake caliper and tie it up out of the way.
The drive shaft nuts can now be removed.
The nearside drive shaft should be pushed through the hub and then popped or levered out of the gearbox. This can be a fiddle as it is held in place by a snap ring. Do not pull the driveshaft out as this might damage the inner plunge joint.
The off side drive shaft should be removed by removing the jackshaft bracket bolts then pushing the driveshaft through the hub. The offside driveshaft has no circlip at the gearbox and will slip out easily.
The drive shafts can be left supported by the suspension yolks but make sure they are not in the way of the gearbox.
At this point support the gearbox and engine from above or below using a trolley jack.
I used a bracket to support the engine from above and I placed a trolley jack under the sump. I also put a strap around the gearbox and over the support frame up above.
15. Remove the prongeron and the front damper along with two of the bellhousing bolts. Start at the front of the car and work your way back.
16. Now remove the exhaust downpipe
17. Remove the four bolts securing the flywheel cover plate.
18. Its time to remove the rear engine mount bracket.
Alan Head
Postby Alan Head » Tue 22.10.2013, 22:08
19. Now remove the gearbox mount. This has several parts, a damper and a couple of L shaped spacer plates.
20. the only thing holding the gearbox on now is three bell housing bolts at the top. These are a bit awkward to get to.
21. The gearbox can now be pulled free from the engine and lowered to the floor.
A few things worth considering before putting it all back together.
It is worth trial fitting the mounts onto the gearbox as you will find you have an awful lot of bits lying around.
Start with the gearbox mount
Then the rear engine mount
Aligning the box is quite tricky but perseverence will pay off.
I hope this post will help anyone considering removing their gearbox or changing a clutch on their Elan.
I scoured the net looking for a similar article but came up with nothing so hope this is useful to the community.
Alan
Alan Head
Postby muley » Wed 23.10.2013, 07:01
Excellent post!
Thank you for taking the time to take pics and post them here - a very useful resource..
Rgds
Postby Rambo » Wed 23.10.2013, 09:05
Could a head honcho or moderator load this onto WikiLEC so that it is available for future reference ?
Postby HJ2 » Wed 23.10.2013, 19:06
Excellent stuff!
A really good write up WITH piccies :-)
Keep up the good work, gotta love this 8)
Postby tb10 » Wed 23.10.2013, 19:09
:clap:
:cheers:
tb10
Postby Steve A » Thu 24.10.2013, 01:55
:bowdown: Great posting Alan,thanks for taking the time :clap:
I hope I never need to use it though :wink:
Postby rip » Fri 25.10.2013, 21:51
Rambo wrote:Could a head honcho or moderator load this onto WikiLEC so that it is available for future reference ?
I'm not either but I have a wiki account. :D
I've put the info there but I can't work out how to embed the photos so it looks a bit of a mess at the moment. I've asked someone who looks a little like you if he can help with it.
Postby RichardK » Sat 26.10.2013, 02:01
This is excellent Alan, thank you very much for posting.
:cheers:
Richard
RichardK
Postby Alan Head » Sun 27.10.2013, 08:39
Thanks for transferring the details to the WIKI.
I am happy for my post on repairing the bouncy headlight pods to be added as well if you have the time or inclination.
viewtopic.php?f=80&t=22415
Alan
Alan Head
Postby rip » Wed 30.10.2013, 22:41
Alan Head wrote:Thanks for transferring the details to the WIKI.
Now updated so the pictures display properly.
Alan Head wrote:I am happy for my post on repairing the bouncy headlight pods to be added as well if you have the time or inclination.
Done.
Nice articles. Both useful additions.
Postby texas2201 » Tue 31.12.2013, 02:44
how long did the job take?
Postby HJ2 » Tue 31.12.2013, 10:50
HJ2 wrote:Excellent stuff!
Turns out that at the moment i need this info just now! :cry:
Is it worth to replace the clutch whilst i get the transmission off?
And if yes, what brand should i use? (Sachs?)
Postby dapinky » Tue 31.12.2013, 11:04
Henk-Jan,
"Is it worth replacing the clutch?" is a very difficult one to answer......
.....When i changed the engine in the red car it had about 135K miles on it, and the clutch (original - or at least, nowt in the huge pile of paperwork to say it had ever been swapped) was still good. Pleanty of meat left on the plate and no slippage.
That said, if you have a chipped car, it will be putting more strain on the clutch, so it will wear faster.
BUT - the clutch is designed to move a much heavier car than the elan, so is engineered to overcome much larger resistance forces than it encounters with us.
It is very rare to read anything on LEC about 'Clutch failure' so it is reasonable to think it isn't a big problem.....
That said, it is so much hassle to get that far anyway, so it may as well get changed whilst you're in there - not something you'll want to do in a hurry if you can do it at the same time...... and even if it shows no sign of wear at the moment, the springs on the cover plate will have weakened with time/use, and likewise the release bearing.
So, on balance, I'd say "Change it!" (and maybe put a new rubber seal on the crankshaft whilst you're there - just to preserve the new clutch)
Postby Alan Head » Wed 01.01.2014, 16:02
texas2201 wrote:how long did the job take?
My garage is rather cramped and I only have basic tools. The only specialist equipment I used was an engine support that sat across the engine bay.
I took my time as this was the first time I had done anything other than routine servicing on the Elan. I was also taking photos as I progressed. I took two days to remove the gearbox (Saturday and Sunday). The gearbox was at Voigts for 5 days. I then spent a further 2 days putting everything back together.
If I did the job again without recording progress I could probably get the gearbox out in 1 day and put it back in in 1 day.
Alan Head
Postby texas2201 » Thu 16.01.2014, 17:38
Thanks Alan - are you in Hamilton in Scotland? If so I went to School there :-)
Where are Voights? just googled it and they are in Liverpool and how much did it cost to have the gearbox rebuilt?
Martin
