Tie Rod
Drivetrain problems
Tie Rod
Postby olata » Thu 11.12.2014, 14:45
It can be difficult to find the tie rod for M100. I was lucky to find a used in good condition for M100. However, I have done some "Research" and found out that Renault Megane might suit. Does anyone have experience with this or have other tie rod that fits? M100 and Megane tie rod are not identical but have the same length 270 mm and M14x1.5 threads at both ends. I have some pictures, but have trouble viewing them on this page.
I bought Megane tie rod by Euro Car Parts with part no. 600745295 (also Renault Scenic)
Here I had had stated TWR JAR992 (fits Vauxhall and Fiat) as a tie rod with the right Dimensions. I ordered a TWR JAR992 but it is unfortunately not correct. The TWR JAR992 I got is about 40 mm longer than the original tie rod for M100. In the datasheet the length is 269 mm, but this seems to be wrong. However, it seems that the one I mentioned above to Renault may be an ok substitute.
olata
Re: Tie Rod
Postby discovery1 » Fri 19.12.2014, 16:54
I also require a replacement tie rod , lots out there with similar measurements and most likely will fit but wonder if anyone has found exact replacement.
discovery1
