Drivetrain problems
by RichardK » Tue 14.06.2016, 08:42
If you have had your RH driveshaft out or loosened the two bolts that hold the jack shaft bearing support bracket then PLEASE check to see if they are still tight, I am pretty sure that two years ago when I replaced the front wheel bearings they were properly torqued up. No locktite though,
TIFU - in the middle of nowhere on a long fast run from Cape Town & made the decision to limp home until I couldn't.....
Rich
RichardK
by chrisP » Thu 22.09.2016, 10:56
I have only just seen your post, I had exactly the same problem a few years ago, the bolts worked loose and the shaft came out of the gearbox, I now double check them each time I change the oil filter!
chrisP
by Artaban » Thu 22.09.2016, 12:34
I check them regularly now as well. A few years back I had only one of the two bolts holding it on. SJ's thankfully spotted it in time while servicing the car. Ross at SJ's thought it might be a non standard thread on the bolt. Does anyone know what it is as the parts guide is no help at all in identifying the spec of the bolts? They don't appear to have a part number?
Andy
Artaban
by Brit-Car-Nut » Thu 22.09.2016, 14:12
They are part number A100F6034F. I will try to remember to pull one and get the thread size/pitch. I don't think it is weird, but they DO have a short shoulder.
Most short bolts you can buy locally are fully threaded. These are short but with a shoulder so the threads don't wear the hole in the jack shaft if the bolts were to come loose.
by dapinky » Thu 22.09.2016, 14:57
Again, going from memory (because i was in the same boat with loose bolts!), the thread is fairly standard, but the spanner size wasn't what you'd normally have for that thread....
.... my (failing!) memory seems to recall that it is a 14mm spanner size, but an M10 thread???? (M10 normally has a 17mm head)....
...but I could be totally wrong
- LEC Administrator
by Artaban » Thu 22.09.2016, 16:03
It would be useful to know as I want to be sure I've got the correct bolts in there. I think Ross was referring to the thread pitch at the time as not being standard but I'm not sure what he meant by that. Maybe standard for Isuzu but non standard for Lotus. Is anything standard on a Lotus.
I did take one off to the local fasteners but they couldn't match it.
Andy
Artaban
by Brit-Car-Nut » Thu 22.09.2016, 23:06
Still a good part number. £3.60 each + vat from Lotus Dealers.
Brit-Car-Nut on Thu 22.09.2016, 23:25, edited 1 time in total.
by dapinky » Thu 22.09.2016, 23:18
John,
Not sure where the specs came from, or if you measured them yourself from one in your stock, but it doesn't look right in all dimensions....
...the picture indicates an M10 thread, but also a 10mm head (which it clearly isn't from the picture).
Probably just a typo - but if that is wrong, and it came from an 'official' source, then are the other dims correct?
- LEC Administrator
by Brit-Car-Nut » Thu 22.09.2016, 23:21
dapinky wrote:John,
The thread is 10mm 1.5 and the head is 14mm. Sorry for the typo. Now fixed.
