by SteveMac » Thu 05.01.2017, 20:27
Hi all, my car has a problem with the clutch assembly. The clutch itself works fine but there is a noise coming from the clutch when the pedal is NOT depressed. When I press the pedal, the noise goes. It's a squeal, sounds like the release bearing but I thought this would be a problem when pressing the pedal not when its released.
I have the cable correctly adjusted with a little play at the lever. Any idea?
SteveMac
by alan e » Thu 05.01.2017, 20:44
No a clutch release bearing can be noisy with no pressure on the pedal, will the noise stop with only a small amount of pressure on the pedal ?
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
by SteveMac » Thu 05.01.2017, 21:13
Yes it stops with light pressure on the pedal. Is there some kind of fix that does not involve replacement?
SteveMac
by alan e » Thu 05.01.2017, 22:02
SteveMac wrote:Yes it stops with light pressure on the pedal. Is there some kind of fix that does not involve replacement?
Sorry not that I know of if its the bearing which it sounds like it is, its gearbox out new bearing and worth changing the clutch at the same time.
2010 black evora
MG ZS EV
alan e
