Clutch replacement / who has used what ?
Postby clemo » Wed 17.05.2017, 09:59
Hi all ,
Engine out so seems a logical time to put a new clutch in ... (96 N S2)
Any best buys ?
From who ?
saw this one ... anyone have any thoughts ?
http://www.ebay.co.uk/itm/LOTUS-ELAN-1- ... I_lEDb2xNg
Thank you
clemo
Re: Clutch replacement / who has used what ?
Postby dapinky » Wed 17.05.2017, 10:32
Exedy are a good make, and I believe that there was a bit of a 'group buy' on some of their clutches many years ago (before I was on the forum).
That said, I am sure that there are different 'qualities' within their range, and I don't know where this one fits.
The price seems high to me (but maybe because I paid $33 for mine last year as a 'closeout' from Rock Autos on a Valeo unit.
I wish to draw your attention to RA website though - they are listing clutches for the Impulse Turbo, BUT they are wrong for the Elan, so don't just buy blindly from them.
The Turbo Elan uses an 8 7/8" driven plate, whilst the NA uses a 7 7/8" plate. Both have the same fittments to the flywheel and gearbox splines, but (obviously) one is much bigger surface area.... I don't know if the Impulse Turbo had the larger or smaller one, but they list the smaller on their site for all Isuzu engines.
FYI, the Valeo part numbers (for the 3-part complete kit) are:-
# 52252802 for the one i bought - correct for Elan Turbo
# 52252202 for the smaller one (for the NA)
As you can see, only one digit different on the number, but a big difference in the car.
Postby dapinky » Wed 17.05.2017, 11:07
Having just had a squint, I see that RA have a selection of kits in the right size - including a Exedy 09017 at £132.85..... but the internet shows that to be an 8 1/2" plate (215mm).
Further research shows a LuK kit with the same numeric part number (09017) - at a very reasonable £83.35 from RA....... and by looking everywhere on t'interweb, they say that they don't list a kit for an elan.......
.... however, the 09017 is for the Impulse turbo, and has the 8 1/2" disc, with the correct splines.
As such, I conclude that it will (probably!) be the right one.
LuK are a well-known and respected brand - and are OE suppliers for VW/Audi Group cars (whether that is good or bad, is for you to discern).
Bottom line - I wouldn't get the one you linked to when the same can be got elsewhere cheaper (but will take a few days to get here).
If it were me, I'd buy the LuK kit
(except I wouldn't, as I still have my Valeo kit sitting in the conservatory - - so, basically, if you need it in a hurry you have a limited choice in the UK......
......... unless someone who has one is happy for you to have theirs on the understanding that you replaced it with a suitable - possibly LuK - kit once it arrives from RA.)
even bottomer line - it appears that Lotus did their usual trick of 'parts bin engineering' for the clutch on the elan - the part numbers as referred to above are standard bits on the Isuzu 1.8 engine as used in the Impulse (and others) - - maybe they thought the Impulse 1.6 unit was going to be too small for the torque in a lighter car?????)
Postby Simon_P » Wed 17.05.2017, 16:16
The correct clutch plate has six coil springs in it the (usually) cheaper ones have four.
Postby HJ2 » Wed 17.05.2017, 21:22
I used the Exedy kit from RA 2 times now without any complaints
Postby Rambo » Wed 17.05.2017, 21:50
HJ2 wrote:I used the Exedy kit from RA 2 times now without any complaints
Twice ??
In over 40 years driving all sorts of vehicles (over 850,000 miles) I've never ever had to replace a clutch
Plenty of discs and pads, but never a clutch :?
Postby HJ2 » Wed 17.05.2017, 22:45
Not on the same car you dummy :lol:
When the car has more than 100k kilometres and the gearbox needs to come off for some reason, I prefer to exchange the clutch as well.
Postby Rambo » Thu 18.05.2017, 09:32
A good idea if the gearbox has to come out :wink:
Postby clemo » Thu 18.05.2017, 11:33
speedy from rock autos it is then .
thanks guys
clemo
Postby chrisP » Tue 24.04.2018, 18:01
A quick update the LUK 09017 Clutch kit is no good for our cars, despite being advertised on Rockauto as being a 8 7/8" clutch plate it is in fact 8 1/2" - After taking 22 days to arrive!!!!
chrisP
Postby chrisP » Tue 24.04.2018, 18:02
It also seems no matter what one you buy, the pressure plate is the same (marked up as DK)
chrisP
Postby Brit-Car-Nut » Tue 24.04.2018, 18:21
"More Info from Rock Auto:"
LUK 09017 RepSet®
Clutch Disc Diameter 8-7/8"
Clutch Disc Spline Quantity 14
Clutch Plate Facing Outer Diameter 8-1/2"
Input Shaft Diameter 1"
Kit Contents Cover Assembly, Clutch Disc, Release Bearing, all Necessary Pilots, Accessory Pack
Number of clutch disc springs 4
Pressure Plate Type Push Type Diaphragm
Possible Solution?
M-PACT 381032D 8-7/8" X 1" X 14T Info
Turbo (Only 11 Remaining) $28.79
Postby chrisP » Wed 25.04.2018, 10:37
I have had problems with the Valeo clutch slipping, however after taking the gearbox off there are no signs of why this is happening. So now as I cannot return the Luk clutch as it is outside Rockautos 30 day return window (and taking 22 days to arrive :shock: ) I suspect the clutch spring is faulty in the existing cover plate so will replace it with the one from the Luk kit and use my old (2000 mile) clutch plate.
I have three pressure plates from different clutch suppliers which are in fact exactly the same item.
Thanks for looking at Rockauto again for me though.
I just wanted to make sure no one else made the same mistake
chrisP
Postby RonR » Wed 25.04.2018, 13:28
Thanks for flagging the problems with the LUK clutches Chris.
I've just ordered a Sachs K7004701 kit from RA, more expensive but the "info" photo shows 6 diaphragm springs so it looks right....
Strangely the photo also shows a "Valeo" marking on the plate, so I'll be keeping my fingers crossed when opening the box.
Ron
Postby chrisP » Wed 25.04.2018, 16:46
Check the size as soon as it arrives Ron, so you are not in the same 'no return' situation that I am in. Is yours being shipped from the States?
chrisP
Postby RonR » Thu 26.04.2018, 11:24
Yes, looks like it's coming from Texas and due to arrive early next week.
I'll post here when I've checked it.
Postby RonR » Mon 30.04.2018, 18:03
The Sachs K7004701 clutch kit has now arrived, and:
Both the cover and the plate are 8 7/8 diameter and the plate has 6 springs:
So it looks like it's the right one.
Thanks again Chris, and good luck with yours.
Ron
Postby marvic » Mon 30.04.2018, 23:04
Just looked in my box of bits that came with my car and I’ve got a new kit of the same part number so should be fine. My car has a lightened flywheel and a race type clutch so this one was never used.
1991 Elan M100
1985 Caterham Super Seven
1952 MG TD
marvic
Postby par » Fri 06.07.2018, 17:42
Looks like my clutch is on its way out and will need to be replaced, not bad going as it seems to be the original clutch with the car on 170K.
Anyone know what make of clutch the one listed on SJ Sports will likely be, any of the brands listed above?
If the Sachs type is the correct one listed on RockAuto once you factor in shipping & time it doesn't offer a significant saving over the SJ price, however if there is a quality advantage it may be worth ordering from RA.
par
Postby Tuga2112 » Wed 11.07.2018, 15:13
par wrote:Looks like my clutch is on its way out and will need to be replaced, not bad going as it seems to be the original clutch with the car on 170K.
when i needed to do one. i was refered to rockauto getting an impulse clutch. (bigger size) mine its a satch i think it cost me on the 120-140s kind of range. but i bought 2 of them with timing belt kits as well for the sake of getting all posted together.
i will try to remmeber to check the details when i get home later
