Gear selection
Gear selection
Postby elnaught » Sun 15.04.2018, 22:30
I put my car into first today and it stuck in gear, the gear stick just went sloppy and would not select any other gears, I have tried at the gearbox and you can select all the gears and the gear stick moves in the car as you select them at the box, from reading other posts I guess the is an issue with leaver end/ I need new cables, I would appreciate any thoughts or photos to give me a clue, some of the old posts no longer have images?
elnaught
Re: Gear selection
Postby Brit-Car-Nut » Mon 16.04.2018, 00:08
email sent with some dubious pictures.
Lotus Manuals
Re: Gear selection
Postby HJ2 » Mon 16.04.2018, 08:27
more info:
viewtopic.php?f=48&t=18246&p=238690
viewtopic.php?f=48&t=16771
I am sure that there are some pictures of the inner parts of the gear selector box somewhere on the forum, but i can't find then either...
Re: Gear selection
Postby elnaught » Thu 19.04.2018, 16:10
Thanks for all your help/advice, I found a broken E clip in the tunnel so mystery solved.
Awaiting a new clip from Paul Matty Sports Cars @ £1.40 so for once seems to be a relatively cheap and easy repair, hope I haven't spoken too soon!
elnaught
