Got new plugs gappend and installed. Now the fun begins. Still the cold starting us rough and a lot of "coughing". It wont hold at idle, sonhave to keep on revs until engine warms up a bit. Then it idles at about 900-1000.
Performed a compression test on each cylinder. Counting from passenger (US) side, #1,2,3 all showed between 140 and 150. #4 though was a bit concerning. At first there was no reading at all after a few good cranks. I thought the cylinder rings or head gasket was shot for sure. Then as I kept cranking and the engine started running on the other 3 cylinders, pressure in 4 read a bit sporadic- jumping to 100, going down again, jumping to 120, going down, then it settled at 150, and after shutting off the engine it held the pressure. Makes me think rings and gasket are ok, but perhaps something is going on with the valves. Any ideas you guys can suggest?
