I recently bought a 1991 SE Turbo and am going round the car doing various things that are in need of TLC. The car has a very sloppy gear selection which I have managed to track down to the cable/selector mechanism on the gearbox. Someone has replaced the pin - A100F6114S - with a nut and bolt, the nut and bolt is loose and causes most of the slop.
I have some machining skills and could make a pin as per PN A100F6114S - described as a pivot pin if I had some dimensions. I'm thinking that if the bolt has caused wear I can compensate in making a size specific to my car. As a starting point would anyone know the approx sizes, diameter and length. And are there any plastic/nylon bushes involved in locating the pin as I can make those too.
Pivot pin
https://parts.bellandcolvill.co.uk/?i=1340806&qs=1&MAK=1&MDL=23&TBL=2268&SMA=0&SMO=0&ST=&SC=0&PBID=64503
Photo of bolt in use on my car
https://drive.google.com/file/d/1Ql7iP7qlWFRUza7nxAzkEweYRCiAZ1DN/view?usp=sharing
