Time to replace the clutch?
Postby scottpegler » Sat 08.10.2005, 22:26
I have been having trouble shifting down from 4th to 3rd and occasionally from 3rd to 2nd. There is a slight grinding when doing this particularly when the vehicle is warm. I always back off when I feel it and let the rpms drop until I can shift without the "grind". Is this symptomatic of a clutch failing or synchronizer or...? Thanks in advance.
Scott
scottpegler
Postby Monty » Sun 09.10.2005, 15:21
Is the clutch hi on the pedal? U can adjust the clutch but i haven`t done this yet :roll: U could also be having trouble with u`r gear cables, have a look under the bonnet to see if the cables are ok, they seem to go were the plastic meets the metal bracket :?
Postby scottpegler » Sun 09.10.2005, 18:34
Thanks Monty. I'll check the cables...What is meant by "high on the pedal"?
scottpegler
Postby Monty » Sun 09.10.2005, 19:01
When u lift of the clutch (in gear) is the pedal high when clutch bites, hopefully it might just need adjustment, if u`r clutch was on it`s way out u would imagine the 1st signs would be slipping :?
