S2 Gear cables
S2 Gear cables
Postby Mike_H » Fri 05.01.2007, 22:13
Hi
could anyone tell me the difference between the S2 gear cables and the original SE cables ?
Looking at the parts manual it looks like they also require a different bracket that fixes to the gear box .
Has anyone fitted these to an SE ?
Thanks Mike.
Mike_H
Postby Enright » Fri 05.01.2007, 22:32
Yes, they're preferable to the originals, but I and many others say forget Lotus ones - spend the extra (I say extra but for the pair it's actually cheaper) and get AB's - one of the best upgrades I've ever bought.
Postby WillB » Wed 10.01.2007, 12:29
Hi Mike,
Drop me an IM if you want a set of the AB cables, delivery to NZ no problem
Will
WillB
Postby Kjeld » Fri 12.01.2007, 06:50
Totally agree. This a no brainer upgrade. Like the brake upgrade, the equipment is clearly better engineered. The cables are beefier and the result is a more firm shift pattern and the sense that these cables will be serviceable longer than the originals.
Of course, I would love to hear if there have been failures in Alan's cable set. Kinda doubt it though.
Ready to sell...... I think.
Kjeld
Postby Siegreen » Fri 12.01.2007, 15:30
Not sure if I fully understand this upgrade, can someone tell me please what is the real benefits of uprading the gear cables?
Many thanks
Si
I fart in your general direction! You mother was a hamster and your father smelt of elderberries!"
Azure Blue S2 No. 452
Siegreen
Postby Enright » Fri 12.01.2007, 15:44
The difference between a rifle bolt and a wooden spoon in a bowl of treacle.
